Fram ph3657 cut open
by jhellwig
1 minute 15 seconds ago
Don't discount coal for a long while yet...
by Shannow
Today at 03:10 AM
Decent Wireless Computer Headset?
by 99Saturn
Yesterday at 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
Yesterday at 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
Yesterday at 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
Yesterday at 10:00 PM
Fram TG 7317 6k miles
by bbhero
Yesterday at 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
Yesterday at 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
Yesterday at 08:56 PM
Second lawn mower blade
by greasegunn
Yesterday at 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
Yesterday at 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
Yesterday at 04:47 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
23 registered (b1amgm47, ChristianReske, BobsArmory, barkingspider, crazyoildude, 4 invisible), 798 Guests and 12 Spiders online.
58272 Members
66 Forums
250819 Topics
#3127058 - 09/16/13 09:43 PM Seeking advice from Bull experts: '03 Taurus
faramir9 Offline
Loc: PA
So, the lady got a 2003 Ford Taurus SES Deluxe with the 3.0 Duratec recently. I don't know much about the Taurus, having never driven one before hers.
It's in good shape, considering it just hit 152K miles. A little paint peeling on the hood, the wheels look like they've seen plenty of outdoor duty and probably salt, but mechanically it seems sound to me. As I said, I am no Taurus expert.
Anything in particular to look out for with this car?
Thanks.
2000 Saturn SL1, 1.9 SOHC
Pennzoil HM 5w-30, TF-335 filter
Nokian WRG3 185/65R14
#3127074 - 09/16/13 10:02 PM Re: Seeking advice from Bull experts: '03 Taurus [Re: faramir9]
The_Eric Offline
Loc: Iowa
In general, decent platform. Look for degraded vacuum hose ends (molded rubber elbows) and various other vacuum related hoses. They like to rot out and kick lean codes. Ford has some updated parts available. The engine isn't the easiest to work on either...
Look for broken springs in the strut assemblies as well as bad sway bar end links.
Edited by The_Eric (09/16/13 10:11 PM)
Edit Reason: spelling
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3127079 - 09/16/13 10:11 PM Re: Seeking advice from Bull experts: '03 Taurus [Re: The_Eric]
Thax Offline
Loc: VA
Originally Posted By: The_Eric
In general, descent platform. Look for degraded vacuum hose ends (molded rubber elbows) and various other vacuum related hoses. They like to rot out and kick lean codes. Ford has some updated parts available. The engine isn't the easiest to work on either...
The Eric pretty much summed it up on the Taurus. Degraded vacuum hoses from Ford are notorious for throwing P0171 & PP0174 codes. As preventative maintenance I would change all fluid and give it a nice tune up. Spark plugs can be a pain as the upper manifold needs to come off in order to reach the rear plugs. Give the MAF a good solid cleaning with electrical spray as well. These were decent cars (boring) but made very good daily drivers.
97 Grand Prix GTP
11 Jetta 2.5 SE
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Technician
#3127084 - 09/16/13 10:15 PM Re: Seeking advice from Bull experts: '03 Taurus [Re: faramir9]
gregk24 Offline
Loc: FL, USA
Watch out for the transmission. They like to [censored] out early
2012 Honda Accord EX-L
Taffeta White - Ivory
39,xxx miles
PPPP 0w20 / Fram Ultra
#3127089 - 09/16/13 10:22 PM Re: Seeking advice from Bull experts: '03 Taurus [Re: gregk24]
Thax Offline
Loc: VA
Gregk25 has a point , perhaps a auxiliary Trans cooler and a few drain and fills would be a good idea.
97 Grand Prix GTP
11 Jetta 2.5 SE
#3127091 - 09/16/13 10:23 PM Re: Seeking advice from Bull experts: '03 Taurus [Re: gregk24]
methusaleh Offline
Loc: Mt. Mansfield, VT
x2, big time! Just for good measure, change the fluid and filter if you aren't relatively sure when it was last done. At the very least look and sniff what's in there.
#3127094 - 09/16/13 10:27 PM Re: Seeking advice from Bull experts: '03 Taurus [Re: faramir9]
Chris142 Offline
Loc: apple valley, ca
Keep fresh coolant in it or it will rust up and plug the heater and radiater. You don't want to replace either on this car.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3127109 - 09/16/13 10:56 PM Re: Seeking advice from Bull experts: '03 Taurus [Re: methusaleh]
faramir9 Offline
Loc: PA
Thanks to all for the replies and advice. Will check the tranny fluid tomorrow....
#3127194 - 09/17/13 05:00 AM Re: Seeking advice from Bull experts: '03 Taurus [Re: faramir9]
Roadkingnc Offline
Loc: NC USA
Good car, keep it serviced and drive it.
The duratec doesn't have a problem with the cooling system but the Vulcan engine does. Trans failure isn't all that common but does happen.
#3127211 - 09/17/13 05:56 AM Re: Seeking advice from Bull experts: '03 Taurus [Re: Chris142]
Miller88 Offline
Loc: Onondaga County
The aluminum Duratec engine wasn't too bad with coolant. The cast iron Vulcan engine was HORRIBLE with coolant crud.
The biggest problem with them is rust. Check the metal coolant lines and the PS lines. The springs like to break.
Throw a transmission cooler on it.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3127246 - 09/17/13 07:17 AM Re: Seeking advice from Bull experts: '03 Taurus [Re: Miller88]
The_Eric Offline
Loc: Iowa
Agreed on both above points. I've replaced far more GM and Chrysler trannys than Ford. Duratecs are fine with coolant, just treat it like you would a normal system and replace it on schedule. I did forget about the metal coolant pipes though- look around at their condition, especially underneath on the passenger side, I think there is a tube there that will rust. If not, I've confused it with the Vulcan engine...
#3127500 - 09/17/13 11:53 AM Re: Seeking advice from Bull experts: '03 Taurus [Re: faramir9]
Miller88 Offline
I haven't been under the hood of a Duratec powered Taurus, but the metal lines on my Vulcan taurus were rotted bad.
I was leaking about a gallon of coolant a week towards the end.
