1992 Honda Accord- Recently it has been a little rough starting. Sometimes it runs rough for only a second or two when it first starts, sometimes it cranks for a few seconds longer than it should before starting.
This morning, it was really bad, the worst start it's ever had. It took 3 or 4 tries before it finally started, ran rough for a good 4 or 5 seconds and finally smoothed out. It threw the check engine light on too, the first time that's happened. It was on the whole way to work this morning. When I parked the car at work, I noticed it was still idling fast at around 1200 or 1300 rpm. I turned the car off, and turned it right back on again. It started right up, idled normally, and the check engine light was off. I scanned for codes using the check engine light method, and came up with code 56. I searched the internet and can't find out what code 56 means anywhere. Ideas?
