Originally Posted By: RF Overlord
Originally Posted By: TechnoLoGs
Why is it "Wobble?" And will it help me?
See the end that plugs into the socket? See how it's not square, but kind of bulged in the middle? That's to allow the socket to rock back and forth (wobble) to fit in tight places or if you need a slight angle on it.
I found out very very quickly that the wobble socket turns differently than a normal...
Yes, it does...on purpose.
I must have missed something again...so you've abandoned the tapping/knocking sound and are now doing a tune-up?
As for that tapping/knocking, it definitely sounds too hollow to be a rod knock. Any chance there's a dent in the oil pan and something it hitting it internally? Happened to a friend once...
Yes, there is enough evidence as to NOT Rod Knock that I know it is something else. I have my ramps now, too. When I get more funds (I have all the time, need to work on focus,) I can check my sharpie marks to see if yonyon suggested TC hitting bellhousing, and I also strongly feel oil pan may be dented. It looks cratered and appears to be coming from there, honestly.. I can't change torque converters NOR flex plates NOR oil pans with what I have!!!
Just that changing the oil pan.. I need to find an indy! I see one that may do it for $250, but how much labor is involved? I could get another oil pan, I got rid of the spare engine a few days ago. No more 500lbs engine in the back, though I had intended it for donor parts. But it has to do so much before that I just junked it to a shop. So it would be new oil pan, yes.
