new HDM part number for lacrosse headlamp recall
by lucerne06
19 minutes 35 seconds ago
snapper blade control is stiff
by edwardh1
23 minutes 21 seconds ago
is my extension cord bad?
by motor_oil_madman
34 minutes 39 seconds ago
Done with Sandisk USB Sticks
by JHZR2
47 minutes 16 seconds ago
Pineapple Margaritas
by sleddriver
55 minutes 30 seconds ago
Replacing Drywall In The Bathroom (Insulation)
by Warstud
Today at 07:56 PM
351W build with a flat tappet
by ssregal39
Today at 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
Today at 07:12 PM
Car's models of 1990 and now
by HTSS_TR
Today at 07:02 PM
Another dealer oil change story
by mclasser
Today at 06:36 PM
Diagnosing HEI ignition module and ignition system
by Fsharp
Today at 05:58 PM
Spark such way?
by yvon_la
Today at 05:48 PM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
100 registered (AIRJAC3, 2015_PSD, 4WD, 69GTX, 74DartSport, 04SE, 7 invisible), 1567 Guests and 137 Spiders online.
58023 Members
66 Forums
249614 Topics
Page 1 of 2 1 2 >
#3124975 - 09/14/13 08:42 PM Oil suggestions for commercial mowers
jd37055 Offline
Loc: Tennessee
Hello board brothers. Thanks for allowing me to enter your board. I have been running John Deere mowers for a while now. I did have a local dealer and purchased John Deere 10w30 oil. When they closed down I started using Castro gtx 10w30. Then I thought I would try Napa oil. I am on here to see what the members suggest. I really liked the John Deere oil but I need something I can buy local. This year my mowers have been used and abused more than ever. One newer has over 1200 hours and other has over 800 hours. They both have Kawasaki engines. I want to do whats best for them. Synthetic,synthetic blend, extended life or other? For the record I run rotella 15w40 in my power stroke and my wrangler with Napa gold filters.
Thanks for suggestions
#3124981 - 09/14/13 08:47 PM Re: Oil suggestions for commercial mowers [Re: jd37055]
mitsuman47 Offline
Loc: East Texas
Assuming that the mowers take 10w30, rotella t5 10w30 or mobil 1 HM 10w30 would both be great choices. Napa gold filters are great filters for your OPE as well.
Which mowers do you have? How many hours between oil changes?
Edited by mitsuman47 (09/14/13 08:50 PM)
'05 Civic 5MT ~322k mi
QSUD, Mobil 1 oil filter, Fram air filter. 10k mi OCI
Honda HRX217 Mobil 1 HM 10w-30 (rescued from negligent previous owner)
#3124982 - 09/14/13 08:48 PM Re: Oil suggestions for commercial mowers [Re: jd37055]
lubedude13 Offline
Loc: North Carolina
I use Amsoil small engine oil since its synthetic and has the additives designed for small engines
2010 Toyota Camry:
Amsoil Signature Series 0W20
Amsoil Signature Series Trans Fluid
Amsoil ATF Power Steering Fluid
#3124984 - 09/14/13 08:50 PM Re: Oil suggestions for commercial mowers [Re: jd37055]
tomcat27 Offline
Loc: Midwest
Personally I would (and do ) use Rotella. a friend of mine owns a lawn service and has a dozen mowers with the Kawasaki motors. loves them. 2000-3000 hours on them. He uses Pennzoil Yellow bottle. 30W in the summer; 10-30 in spring and fall. so they work great on PYB. once again, I'd "upgrade" to Rotella.
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1995 Jeep ZJ, 1970 Cougar, 2010 Vstar, 1989 Radian
#3125005 - 09/14/13 09:04 PM Re: Oil suggestions for commercial mowers [Re: jd37055]
danthaman1980 Offline
Loc: SE Wisconsin
Any HDEO or API SL PCMO in 10W-30 will work well. I use Rotella T5.
2003 Chevy Silverado 1500 5.3 LS Quadrasteer ~224,000 miles; PU 5W-30
2014 Mazda6 Sport 2.5 Skyactiv ~32,000 miles; PP 0W-20
#3125011 - 09/14/13 09:09 PM Re: Oil suggestions for commercial mowers [Re: jd37055]
jd37055 Offline
Loc: Tennessee
They do call for 10w30. I try to go for 75 hours between hours but there has been a few times they have gone 100 hours between oil changes. I see rotella in 15w40 oil often but I guess that's what I look for guess I will look for 10w30 oil.
The amsoil is something I have seen but just not sure where to buy it. I am hoping to get 2000 hours out of these mowers
They are John Deere 757 and 737 models
Thanks for the fast reply
#3125025 - 09/14/13 09:18 PM Re: Oil suggestions for commercial mowers [Re: jd37055]
mattwithcats Offline
Loc: Virginia
A full synthetic 10W-30 or 10W-40 will work.
Don't use a High Mileage oil, it contains seal swellers.
NAPA synthetic can be bought for around $3.50 when its on sale....
However, any decent name brand of 10W-40 will work...
http://manuals.deere.com/cceomview/OMTCU15013_L1/Output/OMTCU15013_L19.html
In the Military, we change Synthetic at 200 hours...
You should be fine at 100 hours...
http://manuals.deere.com/cceomview/OMTCU15013_L1/Output/OMTCU15013_L17.html
Edited by mattwithcats (09/14/13 09:20 PM)
2009 Smart Pure
Pennzoil Platinum Euro 0W-40
Purolator Synthetic PSL 14610
175/55R15 tires...
#3125075 - 09/14/13 10:31 PM Re: Oil suggestions for commercial mowers [Re: danthaman1980]
Gabe Offline
Loc: Indiana
That was my first thought - VR1 or M1 HM. HM oils have slightly more seal conditioners and work great in newer, low mileage motors too.
#3125098 - 09/14/13 11:21 PM Re: Oil suggestions for commercial mowers [Re: jd37055]
Bandito440 Online   content
Loc: NYS
Another vote for Rotella T5 or T6. Pick your flavor.
'14 Grand Cherokee EcoDiesel
Pennzoil Euro L & OEM filter
#3125137 - 09/15/13 12:51 AM Re: Oil suggestions for commercial mowers [Re: jd37055]
Loc: Virginia
Don't run high mileage oil in newer engines
or even engines that don't burn oil or leak..
Seals will swell, then wear, then fail...
2009 Smart Pure
175/55R15 tires...
#3125147 - 09/15/13 01:17 AM Re: Oil suggestions for commercial mowers [Re: mattwithcats]
SuzukiGoat Offline
Loc: Louisiana
Proof?
The vtwin kawi sometimes develop a knock on 20w50... no one has been able to successfully explain way.
I have a bad boy with the vtwin and cut 2.5 acres twice a week, run 10w30 synthetic and a huge mobil1 filter on it. Synthetic is whatever is on sale. The mobil1 filter was just extra and Luckily fit the mower.
Next year is 0w40 mobil1.
20$ a year is cheap insurance for me.
1995 Suzuki Sidekick Auto 4x4 on 33s. Low mileage motor in 200k body. Denso with M1 0w40.
1996 Geo Tracker Auto 4x4 Denso VNG 10w30. 120k.
#3125167 - 09/15/13 02:38 AM Re: Oil suggestions for commercial mowers [Re: jd37055]
Loc: Virginia
2009 Smart Pure
175/55R15 tires...
#3125184 - 09/15/13 04:41 AM Re: Oil suggestions for commercial mowers [Re: jd37055]
SuzukiGoat Offline
Loc: Louisiana
How will using a high mileage synthetic lower oil consumption after using high mileage oil? His info at the end doesn't really add up.
Realistically fuel dilution, a problem for vtwin kawi motors on mower apps, has likely swollen the seals as much as they can get anyways.
I wouldn't try to find a high mileage oil. But I wouldn't avoid it either.
#3125246 - 09/15/13 06:38 AM Re: Oil suggestions for commercial mowers [Re: jd37055]
dnewton3 Offline
Loc: Indianapolis, IN
I have a Scag with the same Kaw engine you likely have, if these are the air-cooled engines.
These are not picky or finicky engines, in terms of lubes. Use any decent dino PCMO or HDEO and you'll be fine. I use Rotella 10w-30 dino lube, but I'm not married to any brand; that just happens to be a fairly easy one for me to get at a good price.
You certainly don't "need" a syn in this application, unless you intend to greatly extend the OCI.
Of note, for a bit of engine info, if you have the vertical shaft a/c engines like mine, then the 19hp through 25hp engines are actually all the same long blocks, and only the intake/carbs are different to vary the power ratings. Only the largest one (25hp) actually uses an oil cooler (block mounted aluminum heat exchanger at the filter mount), but I bought one for my 19hp engine and added it for a very modest price ($35 IIRC). You might consider that if you have concerns for hot oil. However, if you're running a liquid cooled engine, this is not as big a deal.
Edited by dnewton3 (09/15/13 06:41 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3125253 - 09/15/13 06:42 AM Re: Oil suggestions for commercial mowers [Re: mattwithcats]
dnewton3 Offline
After seeing Pat ramble on about filters yesterday, and then suggest the "best" filters are the OEM filters, I officially made a mental note to promptly ignore him from now on ...
Page 1 of 2 1 2 >
