Driving style doesn't change mpg?
by Nick1994
08/30/16 12:30 AM
Autozone 20% off + free shipping
by jmaster
08/30/16 12:20 AM
Beginners guide to external ATF filters?
by buck91
08/29/16 11:27 PM
Good ADBV filter?
by asand1
08/29/16 11:18 PM
my brigs hates synthetic
by meborder
08/29/16 10:39 PM
Butcher factory cooler lines?
by buck91
08/29/16 09:47 PM
Grease for marine davit crane
by davebe
08/29/16 09:10 PM
2016 Traverse, which oil would you use?
by chevman4life
08/29/16 09:08 PM
acclimating to heat - tips, please
by pandus13
08/29/16 08:53 PM
95 Ford Ranger - Runs rough, no power
by dsmith41
08/29/16 08:49 PM
False teeth
by Eddie
08/29/16 08:49 PM
Quaker State engine warranty...thoughts?
by ryan2022
08/29/16 08:46 PM
davebe, Logos, alphanumeric, koidragon1980, iliveonnitro
58961 Registered Users
22 registered (bbhero, edhackett, hpb, Duke, chrisri, 10WSmuckers, 2 invisible), 634 Guests and 10 Spiders online.
58961 Members
66 Forums
253755 Topics
Page 1 of 2 1 2 >
#3124336 - 09/14/13 04:49 AM GM tops in torque~
SteveSRT8 Offline
Loc: Sunny Florida
http://www.foxnews.com/leisure/2013/09/1...intcmp=features
Loving those new DI V8's. Can't wait to see how they run in the real world.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3124342 - 09/14/13 05:25 AM Re: GM tops in torque~ [Re: SteveSRT8]
Silverado12 Offline
Loc: Central Virginia
Put that motor in a regular cab, 2WD 1500 and have some fun.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
15 Chevy Cruze 1LT auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
10 Mustang GT auto
#3124404 - 09/14/13 07:12 AM Re: GM tops in torque~ [Re: SteveSRT8]
hattaresguy Offline
Loc: CT
To bad its only going in the $60k trucks.
That would be a fun motor to have in a lighter truck, or if they made another SS...
Edited by hattaresguy (09/14/13 07:13 AM)
#3124412 - 09/14/13 07:21 AM Re: GM tops in torque~ [Re: SteveSRT8]
Zaedock Offline
Loc: Massachusetts
Perhaps the 6.2L does - for now. The Ford 6.2L has plenty of room for improvement.
The new DI 5.3L GM motor still makes less HP and only 3 ft lbs more Torque than my 5.0L Ford, yet has more displacement. I'm not impressed.
BTW - I tow a LOT and if you pull 11,000+ lbs with a half ton, you're a fool. These "towing wars" with ALL the auto makers are nothing but silly to me.
2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2004 Malibu Maxx LT
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3124418 - 09/14/13 07:33 AM Re: GM tops in torque~ [Re: SteveSRT8]
itguy08 Offline
Loc: Somewhere
A quick tweak to the Ecoboost and it will top GM. My guess is they will up power for 2015's redesign. The 5.0 has LOTS of headroom as does the 6.2.
In the 1500 space, Ram is the one sorely feeling the heat. Lowest payload, lowest tow ratings, and average fuel economy.
#3124422 - 09/14/13 07:42 AM Re: GM tops in torque~ [Re: Zaedock]
95busa Offline
Loc: Tennessee
Amen
2005 Ford F250 Super Duty 4x4
2009 Dodge Grand Caravan
2014 Kia Forte KOUP- totaled by a drunk driver
#3124475 - 09/14/13 08:26 AM Re: GM tops in torque~ [Re: itguy08]
Miller88 Offline
Loc: Onondaga County
I read in a few places that stock, the ecoboast is good for 500/500 ... the problem was that it was blowing up AWD components in the SHO and had to be detuned. I'm sure it would be pretty easy for Ford to up the power a bit more with some software tweaks
The first two was intentional ... they purposely went with coil springs ...
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3124850 - 09/14/13 05:48 PM Re: GM tops in torque~ [Re: Zaedock]
jimmy87 Offline
Loc: texas
Less hp? Only 3 more ft lbs of torque? True, but at what rpm's? Oh and since we are talking about what's been put on paper lets not forget that the GM engine with more "displacement" gets better fuel economy then the 5.0. Direct injection or not the 5.3 is STILL a push rod engine, and of course the 5.0 has DOHC…
2013 GMC SIERRA 5.3L
2002 Toyota highlander 2.4L
#3124859 - 09/14/13 05:53 PM Re: GM tops in torque~ [Re: jimmy87]
OVERKILL Offline
Loc: Ontario, Canada
Isn't the F-150 heavier?
I can see the 5.0L making 500HP with DI. Considering it made 444HP in non-DI BOSS 302 trim.
I don't think anybody is knocking the LSx engines, they are a formidable force. But once shouldn't underestimate their competition either. The current generation of Ford's OHC engines have proven to not only be extremely durable but potent performers as well.
All of the current trucks have awesome engine line-ups IMHO.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3124863 - 09/14/13 05:57 PM Re: GM tops in torque~ [Re: SteveSRT8]
Clevy Offline
Loc: Saskatoon canada
Simple tuning and the ford 5.0 will easily beat those numbers but low rpm grunt is what a truck needs and a dohc engine tends to need rpm for power.
Dodge can likely get more hp from the hemi,and mds helps fuel economy.
I look forward to seeing what happens next
2006 Charger RT
Miles x 2 per oil filter
#3124870 - 09/14/13 06:05 PM Re: GM tops in torque~ [Re: SteveSRT8]
supton Offline
Loc: NH
I dunno. Used to be common to derate motors in trucks. Cars generally don't do heavy loads for long periods of time. Lots of heat gets generated. Has that changed today? As in, vastly better control over hot spots in the engine, and keeping uniform temps, oil issues and whatnot?
2011 Toyota Camry, base, 6spd manual, 119k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 129k, his
#3124873 - 09/14/13 06:11 PM Re: GM tops in torque~ [Re: Clevy]
jimmy87 Offline
Loc: texas
Very true!
"low rpm grunt is what a truck needs",
A. K. A:
LOW END TORQUE!
Edited by jimmy87 (09/14/13 06:13 PM)
#3124878 - 09/14/13 06:20 PM Re: GM tops in torque~ [Re: jimmy87]
OVERKILL Offline
Very true!
A. K. A:
LOW END TORQUE!
Which is where the variable cam timing on a DOHC motor can shine if done right. My M5 makes prodigious torque right off idle and its torque curve looks like Saskatchewan. But it doesn't make peak HP until 6,800RPM.
Ford would be able to work similar magic with their 5.0L.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3124880 - 09/14/13 06:24 PM Re: GM tops in torque~ [Re: OVERKILL]
Duffman77 Offline
Loc: Alberta, Canada
Great comment but there is maybe only 10 guys on this site that can appreciate it.
#3124898 - 09/14/13 06:53 PM Re: GM tops in torque~ [Re: SteveSRT8]
wirelessF Offline
Loc: Oahu, Hawaii
Can't wait for these Gen V's to be in aftermarket applications.
Page 1 of 2 1 2 >
