Originally Posted By: Shannow
No, a positive displacement pump moves the same volume every revolution, regardless of the oil's viscosity.
Positive Displacement Pumps are the superior choice because they are:
1 self priming
2 more or less constant flow regardless of pressure.
3 the effect of viscosity doesn't negatively affect flow...
all good things that will produce a given Gallons per Minute
(GPM) based on the flow rate of a 50 grade viscosity but if drain the
less flowing 50 and install a freer flowing 40 you will definitely
note an increase in Gallons per Minute...
So technically speaking Dr.Haas statement still rings true...
1 self priming
