I'm about 750 miles into my oil change with a K@N filter and 10w40 GTX high mileage oil which is what I used before this change. The K@N didn't seem to really help the cold weather lifter bitching, but I'm not for sure on that yet as the temp has been up and down alot lately. Also, my oil pressure has taken a slight drop from when using the Bosch Premium. Here are average pressures with both filters using 10w40 GTX High Mileage:
Bosch Premium: just under 60psi warm cruising at 75mph, 30psi idle and never any lower, cold idle was at least 70psi sometimes slightly higher
K@N: around 50psi warm cruising at 75, 25psi warm idle, cold idle is 60-65psi
I tried a K@N in my old 4.3 Blazer with similar mileage and noticed consistent pressure drops about the same amount as the Jeep. Has anyone else experienced any of this with these filters?
Jason
Jason
