Accord door lock issue....
by gregk24
07/31/16 12:26 AM
2000 Corolla vvt-i rattle on startup?
by 55Test
07/30/16 11:24 PM
Brought home a beater today
by exranger06
07/30/16 11:03 PM
Can someone explain to me the nomenclature of ammo
by Vern_in_IL
07/30/16 10:52 PM
Common for bad shift solenoids to shift good warm?
by DemoFly
07/30/16 09:50 PM
Riding mower with non bearing front wheels
by JHZR2
07/30/16 09:17 PM
Mail popup
by Eddie
07/30/16 09:05 PM
Tundra headlight restoration..
by kenwin30
07/30/16 09:00 PM
High mileage and severe service...
by OneEyeJack
07/30/16 08:44 PM
Who uses Quicksilver Multi-purpose oil
by BrocLuno
07/30/16 08:07 PM
Gumout Q&A with Ryan Tuerck - Answers
by wwillson
07/30/16 07:37 PM
Friend Picked Up New 2017 Hyundai Santa Fe Today
by crazyoildude
07/30/16 07:07 PM
danthemann, rodder98, kenb777, Indyfan3, RM53119
58651 Registered Users
20 registered (Char Baby, alcyon, 1foxracing, BobsArmory, 4 invisible), 837 Guests and 7 Spiders online.
58651 Members
66 Forums
252471 Topics
#3115166 - 09/04/13 09:05 PM Most accurate ?
OtisBlkR1 Offline
Loc: Indiana
If you had to choose between a Savage heavy barrell bolt .22 magnum
H&R .223 heavy barrel single shot.
Marlin 955ss semi auto .22
scoped and bipod for 100yrd accuracy contest.. what would be your choice ?
06 Silverado 88,xxx Mobil 5-30
11 Acura MDX 49,700 Valvoline syn blend
06 Milan 49,000 PP 5-20
12 Polaris Ranger 800XP 04 RAPTOR 660 06 SUZUKI Z400
#3115210 - 09/04/13 09:29 PM Re: Most accurate ? [Re: OtisBlkR1]
Shannow Online   content
Loc: Oz
3 very different answers to 3 different questions...
What is the use ?
#3115211 - 09/04/13 09:30 PM Re: Most accurate ? [Re: OtisBlkR1]
Stewart Fan Offline
Loc: Everett,Wa.
Savage are well known for accuracy.
#3115265 - 09/04/13 10:19 PM Re: Most accurate ? [Re: OtisBlkR1]
ddtmoto Offline
Loc: Utah
223 all day.....ballistics are not even close, are they?
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
#3115266 - 09/04/13 10:19 PM Re: Most accurate ? [Re: OtisBlkR1]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
We had a Savage 22 target rifle (single shot with the thick barrel, and peep site) no scope, with the peep site at 100 yards you could pick off soda cans, a soda can on its side so you only saw the bottom or the top was a challenge, party balloons were no challenge at all. One time I tried to split a bullet at 75 feet on a piece of rusty angle iron with the point pointing at me. Split the bullet on the first shot leaving scrapes on the rust on both sides.
The trigger pull had a nice set-up for adjusting how hard it was to pull. For long range shooting I made it very lite. The gun started to go off if it was bumped with the safety off, safe handling caused those rounds to safely go downrange. I put the trigger pull back to 3 LB and it still happened. It turned out that the rear screw that holds the stock to the metal of the gun, was sticking up through the threaded hole so that it rubbed the bolt and caused the bolt to fire. Apparently as the wood wears the screw sticks through the metal below the bolt because there is less distance between the head of the screw and the threaded hole. I shortened that screw so it no longer sticks up high enough to touch the bolt. Something to keep an eye out for anytime you put any gun back together if there are any screws that have threaded holes near any part of the gun having anything to do with it firing.
Over the years many boyscouts qualified for the riffle merit badge with that gun, and several adults had fun plinking with it. I had site settings for different ranges wrote into the white felt of the gun case. For a tight group at 100 yards I used yellowjackets.
If you want an accurate gun in general you get more accuracy with a (single shot with the thick barrel). The next best would be a bolt action with the thick barrel. A semi-auto would probably be the least accurate.
If you are buying a used rifle and want accuracy, one big thing to test is weather or not the barrel has had too many rounds through it. I do not know how many rounds it takes to wear out a barrel, and it probably varies with the ammo used, and also how hot the barrel gets because of fast repeated shooting, verses being given time to cool. So if you are buying used, it probably would be a good idea to ask the previous owner who knows that gun what round is the best for accuracy, and then get some of that round and fire quite a few at the intended range to see if the barrel is or is not still good.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#3115363 - 09/05/13 02:57 AM Re: Most accurate ? [Re: JimPghPA]
j_mac Offline
Loc: wv
Better yet,
See if you can still find a CZ 452 in .22LR. Put a decent, very high magnification scope on it. Use SK brand German subsonic target ammo. Place you some quarters at 100 yards and you will hit them almost EVERY time.
That being said, Savage has become one of the best brands believe it or not.
But I don't care what gun you have, if you use Wal-Mart ammo in it, you ain't gonna hit a quarter at 100 yards 90% of the time. American ammo has turned into rot-gut. That is if you can find some.
#3115367 - 09/05/13 03:13 AM Re: Most accurate ? [Re: Shannow]
BobsArmory Online   content
Loc: Michigan
Yes, valid question.
What is the use ?
Keeping the forces of evil at bay.
2007 Cadillac STS
2009 Chevy Silverado
#3115769 - 09/05/13 01:13 PM Re: Most accurate ? [Re: OtisBlkR1]
Astro14 Offline
Loc: Virginia Beach
Thought the intended use was, as the OP said, "accuracy contest."...
But those are 3 different cartridges and 3 different rifles...so, it's hard to separate rifle performance from cartridge and know which would be the more influential factor in ultimate accuracy...
32 Packard 15W40
90 4Runner 10W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
16 Tundra 1794 TGMO
#3115926 - 09/05/13 04:16 PM Re: Most accurate ? [Re: OtisBlkR1]
Loc: Oz
I'd swear that second part wasn't there when I first saw the thread...
Anyway, ditch the magum, then decide how you want to play with the other two.
Standard velocity .22 has less wind drift then the magnum, but a rainbow trajectory. If your range is 100M and 100m only, it's the least cost way of getting holes made.
Got more money, then get a good .223
#3115930 - 09/05/13 04:26 PM Re: Most accurate ? [Re: Astro14]
OtisBlkR1 Offline
Loc: Indiana
Yes sir, Accuracy contest.. and i own these rifles, they are not being considered for purchase.. and believe it or not that semi auto .22 is pretty tight at 100 yards.. Ive never had alot of luck getting the single shot .223 to dial in tight, but ive also not spent alot of time on it as its got some cheap rings on it and replacing them has been on my firearms bucket list.. The savage has a exceptionally clear Nikon pro-staff scope on it but its not very powerfull (scope power) so to even consider it i would need swap out a more powerfull scope on to it. At the moment the only one that a solid performer is the .22 and at 100yards using Remington .22's sometimes the goupings are under 2 inches and sometimes they are up to 3-4 goups (some shooter error involved)
As scarce as ammo is right now i can only tell you what i would be shooting what i have on hand
Remington .22
CCI .22 Magnums
Federal American Eagle .223
I have a handfull of scopes i could put on these weapons, Bushnell Banner 6-24 x50 probably being the most powerfull..
I only have 2 weeks untill this contest and fairly limited time to put the package together and dial it in.
#3116587 - 09/06/13 09:48 AM Re: Most accurate ? [Re: OtisBlkR1]
hatt Offline
Loc: Florida
It looks pretty simple considering your predicament. Put scope on Savage. Take it and Marlin to range. Shoot them. Pick the one that is best.
2013 F150 5.0, PP 10w-30, Wix 57502
2010 Camry 2.5, PP 5w-20, Wix 57047
#3116874 - 09/06/13 03:25 PM Re: Most accurate ? [Re: hatt]
OtisBlkR1 Offline
Loc: Indiana
Its funny you said this, because its exactly what i did. 6-24x40 Bushnell banner on the savage .22 magnum. I bore sighted it this morning and i will shoot tomorrow morning, The Marlin is coming outside with me to (no need to go to the range, my property is the range) between these two i will see wich one i can get to come in tightest.
#3116892 - 09/06/13 03:47 PM Re: Most accurate ? [Re: OtisBlkR1]
OtisBlkR1 Offline
Loc: Indiana
I also figured out why the .223 never came in tight when i tinkered with it before, the Rail is bent, I have no idea how that happend.. After a new rail is put on i will put another scope on it and see where it goes.
#3120693 - 09/10/13 04:18 PM Re: Most accurate ? [Re: OtisBlkR1]
OtisBlkR1 Offline
Loc: Indiana
I think i have a faulty scope, the 24 power went on the .22 magnum savage and it would start dialing in the start throwing rounds 3-4 inches off target.. Im not going to keep wasting ammo on this scope on differend guns, ive got a Bushnell Dusk till Dawn i have still sitting in the box, we can give it a go.
