Hello, long time no post (I had kids). Hope I've picked the correct forum.
I was just given a kerosene heater...dusty, but it cleaned up nicely & appears hardly used. I've drained out the old kerosene (only because I got water past the cap when rinsing it off) - it's pale yellow & the unit says to use "water clear kerosene" (sans water I assume )..i'll give what's on top to my furnace.
My research on where to get kerosene indicated Lowes has K1 by the gallon for $6.90 - but it seems aviation "jet A" fuel is more or less the same & I may be able to get it (haven't called yet) for $3.71 per gallon at a local small airport. I've also read that "jet A" is also obtainable cheaply (or free) as waste, from the routine draining of airport fueling trucks, or jets under repair. I'll call some heating oil suppliers Monday to see if kerosene is available...& if I can come get a 5g jug filled.
I plan on using the heater in the house should the power go out this winter (lotta trees here & a good snow dump can/has/will down power lines for days). Anyone have info on the smell/fumes of "jet A" vs "k1"? Am I correct in assuming a 1500w space heater run off a small generator will provide inferior warmth for fuel consumed? Thanks
