I just installed an oversized oil filter-purolator L22821- on my 2003 Corolla. I chose this because it has the same bypass setting(15-18 psid), gasket size, and the shape of the base is similar to the L14476 that Purolator shows as the filter for my car.
To my question: After I installed the L22821, the clearance between the filter and the edge of the oil pan is only 1/8 inch at most. Is this enough clearance. Puralator also makes the L14477, which is a little bigger than the L14476-but not by much. I can't seem to locate an oversized filter that meets the "original" filters specs. Does anyone have any suggestions. Thanks!.
BTW, I chose Purolator because their catalog is the only one I've seen that list's the spec's for their filters-so I know the filters I buy have similar spec's to the original filter.
