2015 Silverado - Put some chrome
by Realtech214
Today at 10:22 PM
Ticks!
by spasm3
Today at 09:54 PM
shop didn't replace clamps on steering rack
by motor_oil_madman
Today at 09:46 PM
First SSD on Xubuntu 16.04
by Eric Smith
Today at 09:20 PM
Purolator Boss PBL25277
by Quattro Pete
Today at 09:11 PM
Pan w/ drain plug for 62TE
by JTK
Today at 09:04 PM
2007 Explorer 4.0 upper and lower intake gaskets.
by ls1mike
Today at 08:55 PM
Cars... where they belong: On the road!!!
by Spillips
Today at 08:29 PM
I got 'spoofed' !
by Geauxtiger
Today at 07:57 PM
2013 Camry DIY Brake Fluid Replacement Experience
by windeye
Today at 07:26 PM
Pics Husky 525LS ran on XP oil
by Buzzsaw
Today at 07:09 PM
Brake Pad and Rotor opinions
by oilstudent24
Today at 07:02 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
57 registered (901Memphis, alan003, bdcardinal, B320i, Bandito440, ajchien, 4 invisible), 956 Guests and 295 Spiders online.
57779 Members
66 Forums
248388 Topics
Page 2 of 2 < 1 2
#3129334 - 09/19/13 08:09 AM Re: Questions about different oil in same engines. [Re: Spudislander]
Spudislander Offline
Loc: Canada
Originally Posted By: Spudislander
Originally Posted By: Clevy
The ESP oil is formulated for the emissions equipment. It has less of some elements that could possible shorten the life of you're emissions equipment.
I believe the 0w oils are TYPICALLY more advanced than their 5w- counterparts.
Do the 0w oils have better formulation for the emissions equipment vs the 5w20 motor oils? I have a 2013 Mazda 3 with 2.0L motor and Mazda recommends 0w20 whereas the recommended oil for my previous (2009) Mazda 3 with the same motor was 5w20. I was thinking about using some 5w20 Valvoline Synpower which is on sale at the local Walmart. However, if its formulation is not as good for protecting the emissions equipment I will not use it.
Sorry, just realized that I was reading under the Diesel section of the forum. I assume this does not apply the same to gasoline engines.
#3129343 - 09/19/13 08:18 AM Re: Questions about different oil in same engines. [Re: kimandsally]
CivicLX Offline
Loc: FL
Originally Posted By: kimandsally
Hi I'm new so please be gentle.
I have a Ford 2.0l PSA DW engine Ford recommend this: Mobil Super 3000 X1 Formula FE 5W-30
But with the same engine in another car V70 2.0D (D4204T - 100kW) the recommend this:
Mobil Super 3000 X1 Formula FE 5W-30 or this: MOBIL 1 ESP 0W-30
But the same engine in this 407 2.0 HDi 16V FAP/DPF Coupe (DW10BTED4 - 103kW) they recommend this: MOBIL 1 ESP FORMULA 5W-30.
I understand the basics of oil and I get Ford want the use the FE to save fuel but what I don't understand is why Peugeot and Citroen both use the Mobil 1 ESP 5W 30.
I want to use the Mobil 1 ESP 5W 30 I don't care about the minuscule amount fuel I will lose I want the engine to run longer as it will be a while until I can afford to buy another car so I want this to live a long and reliable life.
I know the Peugeots and Citroens use this system:
* a post-injection of fuel in the expansion phase, which generates post-combustion in the cylinder and raises the temperature of the gases by 200 C to 250 C, to around 350C to 400 C.
* additional post-combustion generated by an oxidation catalyser placed upstream of the filter, which treats the unburned hydrocarbons from the post-injection phase. The temperature may increase by a further 100 C, up to 450C or 500 C.
* the fuel additive Eolys fuel additive. This additive lowers the natural particle combustion temperature to 450 C.
And my Ford doesn't use the Eloys fuel additive but it says: The DPF regeneration can be done both actively and passively.
Mobil 1 ESP 5W-30 is for the cars have DPF and that's why it is recommended for your Citroen and Peugeot. However, this oil does not certify Ford 913-C.
For your Ford, either Mobil 1 0W-30 Fuel economy or Mobil Super 3000 X1 Formula FE 5W-30 will be a good choice as they certify Ford 913-C.
2004 Honda Civic Lx [105k] Mobil1 High Mileage 5w-20
#3129423 - 09/19/13 09:46 AM Re: Questions about different oil in same engines. [Re: Spudislander]
jayg Offline
Loc: Anchorage, AK
Right your gas car does not have a DPF that is sensitive to ash deposits.
'15 Toyota Prius C TGMO 0w20
'91 Toyota Land Cruiser VWB 5w30
'73 Datsun 240Z 4sp Vintage QS 10w40 from '73 in the sump
Page 2 of 2 < 1 2
