Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
Car's models of 1990 and now
by HTSS_TR
05/30/16 07:02 PM
Another dealer oil change story
by mclasser
05/30/16 06:36 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
40 registered (CKN, andrewp1998, chrisri, clinebarger, bdcardinal, Abakev, 9 invisible), 751 Guests and 315 Spiders online.
58031 Members
66 Forums
249616 Topics
#3115240 - 09/04/13 09:53 PM soldering on nimh battery
spasm3 Offline
Loc: out there
My wife has this facial scrubber that won't charge anymore, i tore it apart and found 2 nimh aa batteries soldered onto the circuit board tabs with a solder strip on the bottom making them in series. I don't know if its safe to solder on replacement nimh batteries. I would never try it on a lithium ion battery. Should I ?
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3115241 - 09/04/13 09:55 PM Re: soldering on nimh battery [Re: spasm3]
JHZR2 Offline
Loc: New Jersey
All batteries will have degradation due to chemistry changes under heat. There is not a volatile organic electrolyte that will break down at low temperatures as in Li-ion. I would do it but be very cognizant still of how much heat youre putting in - it flows axially very fast as it is in the plane of the current collector.
#3115245 - 09/04/13 09:57 PM Re: soldering on nimh battery [Re: spasm3]
spasm3 Offline
Loc: out there
Thanks !!
#3115276 - 09/04/13 10:31 PM Re: soldering on nimh battery [Re: spasm3]
Michael_P Offline
Loc: By the Lake
Check out cordless phone batteries. I have retrofitted them for many non phone applications.
#3115282 - 09/04/13 10:41 PM Re: soldering on nimh battery [Re: spasm3]
bvance554 Offline
Loc: VA
Yes you can solder Nimh batteries with no worries.
#3115290 - 09/04/13 10:49 PM Re: soldering on nimh battery [Re: spasm3]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
It might be a good idea to be sure there is no oily surfaces by wiping it with some alcohol, and then rough up the surfaces on the batteries with many scratches. Scratches make soldering to a new battery much easier and you will not have to keep the heat on the battery as long as it would take if the surfaces were not scratched.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#3115312 - 09/04/13 11:28 PM Re: soldering on nimh battery [Re: spasm3]
Quest Offline
Loc: beaver land EH?
sand paper and solder flux are your friends.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3115330 - 09/05/13 12:11 AM Re: soldering on nimh battery [Re: spasm3]
mattwithcats Offline
Loc: Virginia
Edited by mattwithcats (09/05/13 12:16 AM)
2009 Smart Pure
Pennzoil Platinum Euro 0W-40
Purolator Synthetic PSL 14610
175/55R15 tires...
#3115339 - 09/05/13 12:54 AM Re: soldering on nimh battery [Re: spasm3]
Andy636 Offline
Loc: Romania
Perfectly safe to do. I used to build my own batteries packs for RC boats and planes use 8-12 NiMH cells and never had a problem but whatever you do stay away from Li batteries smile
Best way to do it is with an arc welder but flux welding works as well.
#3115454 - 09/05/13 07:08 AM Re: soldering on nimh battery [Re: spasm3]
NateDN10 Offline
Loc: Rochester, NY
I have done it before... just do it quickly! Solder flux is a good idea.
2005 Chevrolet Cobalt - 95,000 mi.
2012 Mazda5 - 80,000 mi.
#3115843 - 09/05/13 02:24 PM Re: soldering on nimh battery [Re: spasm3]
Vikas Offline
Loc: NorthEast
I had never heard the wife's instrument being refereed as "facial scrubber" though :-)
Edited by Vikas (09/05/13 02:25 PM)
#3115995 - 09/05/13 05:53 PM Re: soldering on nimh battery [Re: spasm3]
Happy Birthday Papa Bear Offline
Loc: Leamington, ON, Canada ..... r...
Clean & flux the area. Get the iron HOT. Get in and get out. You'll be fine.
I never was too bright - now old age and forgetfulness complicate things as well" crazy
2016 Dodge GC deep cherry CVP drive
#3116897 - 09/06/13 03:55 PM Re: soldering on nimh battery [Re: spasm3]
JimPghPA Offline
If you have not bought the batteries yet, mattwithcats is correct about getting cells with the solder tabs already on them.
Also, look for a "Batteries Plus" store in your area, they can sell you the cells with tabs or even make a pack for you. They usually have a spot welder that will make the small spot welds on metal straps and build the entire pack for you.
BTW, one of the things to keep in mind is that if you have bare wire or uninsulated metal straps as the connections between the cells, be sure they can not touch the outer part of the cells.
JimPghPa
#3117187 - 09/06/13 09:31 PM Re: soldering on nimh battery [Re: JimPghPA]
spasm3 Offline
Loc: out there
Thanks to both of you! I did'nt know i could get them with tabs!
#3117434 - 09/07/13 07:51 AM Re: soldering on nimh battery [Re: Vikas]
Errtt Offline
Loc: California
Ya have now ;>O
