Nexen Tires?
by 2015_PSD
02/11/16 08:02 AM
Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
biyogo, Jandry, BlueKelah, threeeightteen, TOADchunks
56891 Registered Users
78 registered (97K15004WD, 440Magnum, 2015_PSD, 87sammy, 1foxracing, 4 invisible), 1368 Guests and 199 Spiders online.
56891 Members
66 Forums
244535 Topics
#3113512 - 09/03/13 12:32 PM Is all rotella diesel oil?
2000NWXJ Offline
Loc: Oregon
Planning on running either rotella or valvoline 10w30 conventional in my jeep 4.0. Is rotella all diesel oil or is there a special formula for gas vehicles. I know rotella has great uoa's on this engine but I have read that diesel oils can have too much detergent for gas engines.
2000 Jeep Cherokee Classic (XJ) 4.0 I-6
Delo 400 XLE Synblend SAE 10w30
Purolator PureONE
#3113516 - 09/03/13 12:38 PM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
jeepman3071 Offline
Loc: Storrs, Connecticut
Rotella is suitable for use in both diesel and gasoline engines. Use it with confidence. thumbsup
2000 Jeep Cherokee Sport 4.0L (161k) - PYB 5w30, Napa Gold 1516, Magnefine trans filter
#3113520 - 09/03/13 12:40 PM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
I don't believe there is any gasoline-specific Rotella. All I've ever seen are dual rated HDEOs, and there may be some older style two-stroke diesel only versions. There is nothing wrong with running a CJ-4/SM or CJ-4/SN HDEO in a gasoline engine, within certain limitations, of course. It's best if the viscosity is close and the specifications are the same or similar. I'd run 10w-30 Rotella in my old F-150 without hesitation. If I had a new Camry or Prius, I might think over it a bit longer, at least while under warranty, since they likely call for a 0w-20 in SN/GF-5, and the HDEO will certainly not meet the ILSAC specification, much less the viscosity called for.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3113527 - 09/03/13 12:45 PM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
cancov Offline
Loc: North Carolina
All the Rotella starbursts I've looked at have been API SM certified. So assuming your Jeep 4.0 will accept API SM (verify with your manual), and I'm positive it will, then Rotella oils are suitable for your Jeep. All the technical specifications aside, I have no problem using "diesel" oils in my gasoline vehicles. I'm even mixing some Rotella T6, 5W40, in my Corolla with Mobil Clean 5000, 5W20, at about a 1:3 ratio to add some "detergency" and the slightly thicker mixture satisfied my distaste with piston slap at start-up.
'11 Toyota Corolla, Corolla MPG
'86 Mazda B-2000
#3113558 - 09/03/13 01:15 PM Re: Is all rotella diesel oil? [Re: cancov]
I bet you'll find an API Donut on there, and not a Starburst. wink The Starburst indicates ILSAC compliance, and I haven't seen such a Rotella product - Formula Shell, yes, not Rotella, though.
#3113569 - 09/03/13 01:27 PM Re: Is all rotella diesel oil? [Re: Garak]
901Memphis Offline
Loc: Northern Kentucky
Its the API SM Donut on the back of them.
7 Posts down in this thread.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2420723
2002 Buick Century 118k - Built 4T65e - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317
#3113592 - 09/03/13 01:55 PM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
dparm Offline
Loc: Chicago, IL
The diesel thing was done for marketing purposes. It is clearly okay for gasoline engines (most diesel oils are).
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#3113696 - 09/03/13 04:09 PM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
bluesubie Offline
Loc: NJ
Originally Posted By: 2000NWXJ
... but I have read that diesel oils can have too much detergent for gas engines.
I've read this as well and have no idea where this comes from. Not true. People that assume, I suppose.
-Dennis
'04 Subaru Forester 2.5XT
Motul X-clean 5W-30
#3113731 - 09/03/13 04:35 PM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
fdcg27 Offline
Loc: OH
Rotella is a Shell brand of diesel oil.
Many of these oils are dual rated, that is they carry both SAE Cx and Sx ratings, but some grades are strictly C rated.
If you want to use T5, it is dual rated and suitable for API SM applications.
This is a thicker oil than VWB.
The Rotella may have higher detergency but I can't see that causing any problems.
I'd consider it an upgrade over VWB and I'd run it without a second thought.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3114184 - 09/04/13 12:22 AM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
BlueOval Offline
Loc: Alberta, Canada
I am running Petro Canada Duron-E synthetic 5w40 in my 08 Ranger FX4, and if i could marry an oil I would. Smooth as silk. As I was pouring it in I started to second guess myself but the second I turned it over I am in love. The oil is dual rated, Rotella from what i am told is a great oil use without worry...as long as your warranty is up that is lol.
08 Ford Ranger FX4--PC Syn 5w30 MC filter
13 RVR--Petro Canada 5w20 synthetic Hastings Filter
#3114328 - 09/04/13 07:36 AM Re: Is all rotella diesel oil? [Re: 901Memphis]
Yep, API SM/CJ-4, no Starburst, of course, because there's no ILSAC compliance, identical to the API certification mark on the jugs of Mobil Delvac 1 ESP I have in my garage (and in my sump).
#3116171 - 09/05/13 08:30 PM Re: Is all rotella diesel oil? [Re: 2000NWXJ]
artificialist Offline
Loc: Florida
The only Rotella I saw that wasn't approved for gasoline use was T1 SAE30. You would be better off with a multi viscosity oil, so you wouldn't want this oil anyway.
2010 Lancer Ralliart Sportback
