$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
Eating out, beware you all
by CourierDriver
02/10/16 06:13 PM
Best Sponge For Washing Cars
by George7941
02/10/16 06:08 PM
Old school (ethanol) and (leaded) fuels
by mjoekingz28
02/10/16 05:37 PM
Opinions on this oil filter relocation setup
by bspag
02/10/16 04:42 PM
E-brake tightening on Cobalt Chevrolet
by mjoekingz28
02/10/16 04:32 PM
Mobil 1 EP rollbacks at local Walmart
by HTSS_TR
02/10/16 04:29 PM
GM worker Saves a life on company property.
by Charlie1935
02/10/16 03:43 PM
Idle wear
by DrRoughneck
02/10/16 03:27 PM
Download a WHOLE site? AllData, Toyota TIS etc
by SumpChump
02/10/16 03:07 PM
Mixing washer fluid with windex?
by 55Test
02/10/16 02:48 PM
Car won't start, no gas movement observed, pump?
by Hal9000
02/10/16 02:39 PM
Miningman, pocketdrummer, bspag, Lana, phem0r
56883 Registered Users
107 registered (akela, 901Memphis, Astro14, adamrc, bdcardinal, Abakev, 13 invisible), 1559 Guests and 207 Spiders online.
56883 Members
66 Forums
244520 Topics
Page 2 of 2 < 1 2
#2688352 - 07/19/12 02:26 AM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Texan4Life Offline
Loc: Texas
I have heard of trucking companies mixing waste oil in their fuel @ 1%.
Supposedly to much waste oil (or straight veg oil) will cause buildup on the rings, valves, and injector tips. Also as mentioned some pumps are sensitive to viscosity.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#2989096 - 04/30/13 08:34 AM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Sprocket Offline
Loc: Spain, Valencia
All the common rail are sensitives, and the rotary pumps made by Delphi-Lucas.
The Bosch PE (lineal) and the rotary VE runs perfect.
The Bosch VP 44 is to much sensitive to fuel viscosity, runs ok but makes excessive hot.
You can mix @ 3-5%, no issues.
#3075454 - 07/24/13 09:22 PM Re: Used engine oil instead of WVO? [Re: Texan4Life]
matt922 Offline
Loc: Gulfport, MS
my dad did it during the late 80s- early 90s when he maintained a ~40 truck fleet. The drivers hated it because they always had to carry a spare fuel filter with them just in case.. Unsure of the actual dilution ratio though..
Volvo S60 T5
#3115823 - 09/05/13 02:00 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Miller88 Offline
Loc: Onondaga County
I've always wanted to get an old mech. injection diesel and run waste oil in it!
Up here, truck drivers are pretty used to carrying spare fuel filters. When they gel up, first thing you have to do is change the filter!
I run the 10w30 becuase 0w20 makes my CVT shift funny
#3422650 - 07/12/14 01:12 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
sixtwoturbo Offline
Loc: Abbotsford, BC
See sig, I run 70-100% WMO/Transmission oil/Hydraulic oil and jet fuel all the time.
If you filter and prep it properly, then the risks are reduced. Sure, you will have to clean injectors at some point but big deal. I average 30 gallons a week and have done so since November and haven't touched her except to change the oil, which I reused, hehehehe. I also put a cleaner in the tank every other fill and run an additive every fill.
People do run it in newer diesels but IDI diesels will take anything you can throw at them and are cheaper to fix/maintain.
1984 G20 Get A Way van, 6.2 diesel with a remote mounted turbo-HX35 with a billet 60mm HX40 comp wheel, 20 psi, running waste fuels and jet fuel.
#3938145 - 12/05/15 05:15 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
GumbyJarvis Online   happy
Loc: Fort Hood, TX
I've ran JP8 + 15w40 in Mraps and hmmwvs and lmtvs many times.
When an engine is built for diesel and you use jet fuel in it, things tend to leak due to lack o lube in fuel
No issues. Actually the MAXXPRO Started heck of a lot better in Afghan Mountains with the oil in the fuel when it got to sub freezing negative degrees and snow.
I always did 1 qt to 20L of fuel. New or used oil. Safety Kleen 15w40 mil spec oil
13 Dodge Dart SXT 2.0L 40k MI
Castrol Edge 0w40 + Ultra
05 Ford Ranger 2.3L 225K MI
Havoline 10W40 + Purflux
M1A2 SEPV2 6k MI
Royco 560 + Purolator
#3938148 - 12/05/15 05:18 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Loc: Fort Hood, TX
Shoot. The 6.2 non turbo and 6.5 turbo hmmwv engines are noticably quieter with the mix. And they're pretty noisy engines.
Also, the cylinders have a easier "feel" to them while driving and accelerating
M1A2 SEPV2 6k MI
#3938441 - 12/06/15 01:00 AM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Shannow Online   content
Loc: Oz
Here's a cutapart of my last fuel filter, which had 15L of used engine oil in 3,000L of total fuel consumption.
http://www.bobistheoilguy.com/forums/ubb...in_#Post3875071
Given the novel design, you can see that it was capable of trapping most of the gunk, early into the flow path...not sure how it would have gone with double the waste oil or more.
That design, the fuel does multiple passes through the filter, the fuel cleans up really well in service.
Page 2 of 2 < 1 2
