2 questions here regarding a 2012 Arctic Cat HDX700 SxS.
1) Years ago, Cat updated the oil filter from A/C Part No. 0812-029 to the current 0812-034. That fine. When I go to Wix site and enter either #, it tells me to use Wix 57937. Great. Then I went to Fram site and entered both A/C Part #'s and Fram tells me to use a Fram PH6018. Wonderful. When I went back to the Wix site to confirm, I entered in Fram's 6018, and instead of getting Wix 57937 as expected, I get Wix 51359. So I compared the specs of the 2 Wix filtes and they are totally different- beta ratio, bypass valve, etc. The Fram filter is different than both Wix as well. I would like to use a Wix, but since Arctic Cat doesn't publish technical specs of the filter, I don't know which Wix would match most closely to A/C?
2) I believe this Prowler HDX requires a wet-clutch oil, so I purchased a case of Amsoil 0W-40 PowerSports oil. Is any HDEO safe to use as well?
