Keep it simple.
by JustinH
05/06/16 03:28 PM
Pennzoil Ultra Platinum, 5W-30, 5k OCI, 20k total
by Joshua_Skinner
05/06/16 02:26 PM
Amsoil 75w90, 45K, 04 Chevy Tahoe
by dhellman12
05/06/16 02:09 PM
What happened to this kind of oil change?
by OneEyeJack
05/06/16 01:44 PM
OH! OH! Gas/Diesel mixup
by azjake
05/06/16 01:09 PM
VOA Pennzoil Platinum Euro 5w40 - SN
by agpatel
05/06/16 12:36 PM
VOA Liqui Moly Leichtlauf High Tech 5w40
by agpatel
05/06/16 12:30 PM
VOA Castrol Edge with Ti - 0w40 - SN - Euro Form
by agpatel
05/06/16 12:27 PM
Magnatec 5w30 - Push Mower
by SavagePatch
05/06/16 11:31 AM
RAM 1500 EcoDiesel filter
by pb379
05/06/16 09:14 AM
Motul 8100 X-Cess 5W/40 11,568Miles BMW335i
by strongmad
05/06/16 08:52 AM
Lawn Tractor Utility Upgrade
by bigdreama
05/06/16 08:50 AM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
95 registered (69GTX, 137_Trenton, 2010Civic, 09_GXP, asand1, 12 invisible), 1 Guest and 0 Spiders online.
57814 Members
66 Forums
248551 Topics
Page 1 of 5 1 2 3 4 5 >
#3114828 - 09/04/13 04:46 PM Seizing caliper?
OVERKILL Offline
Loc: Ontario, Canada
On the M5.
I developed a "squeek squeek squeek" from the right front wheel that goes away the instant you touch the brake pedal.
Brake pads are relatively new and have PLENTY of meat on them.
Rotors are OE and were machined.
There appears to be a little bit of a thickness variation in the rotor (can't feel it in the pedal) because with this wheel off the ground:
A). It doesn't "spin" freely. You can rotate it, but it doesn't continue to spin.
B). If you spin it fast enough you can reproduce the squeek.
C). There's a small "easy" spot when rotating it where it spins easier, but then goes back to the way it was.
Yesterday I pulled the wheel looking for the source of the noise. It seemed to come from the caliper/pad/rotor interface.
I removed the caliper.
I was able to then "spin" the rotor with very little effort and it kept spinning with no funny feel to it at all. So the wheel bearing is fine.
I took a file to all the sliding surfaces, pulled the pins, cleaned them, lubed everything with Permatex synthetic brake lube and reassembled.
Problem is still there. It is like the caliper is putting just a bit of pressure on the pad and it shouldn't be. The calipers are original, and while not "high mileage", they are old. I'm not sure if the original owner ever had the brake fluid changed either. Most likely not.
I'm thinking the caliper is on its way out.
Thoughts?
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3114839 - 09/04/13 04:53 PM Re: Seizing caliper? [Re: OVERKILL]
heynow Offline
Loc: Nevada
How long ago were the rotors machined?
How long after the machining did the noise begin?
1991 Acura NSX
1991 Suzuki Samurai
2005 BMW r1200GS
#3114866 - 09/04/13 05:08 PM Re: Seizing caliper? [Re: OVERKILL]
chrome Offline
Loc: Melbourne, Australia
In a lot of caliper design, the seal on the piston is designed to slightly retract the piston when the hydraulic pressure is relieved.
Perhaps in your case, there's slight corrosion in the bore, just enough to prevent the piston from retracting. Are you able to rebuild the caliper yourself?
#3114875 - 09/04/13 05:14 PM Re: Seizing caliper? [Re: heynow]
Tegger Offline
Loc: Canada
You will obtain substantial and critical information by closely comparing BOTH sides to each other.
1) Raise the entire front end so BOTH wheels are off the ground at the same time (use center jacking point).
2) Remove BOTH front wheels.
3) Remove BOTH front calipers (and hang them from the springs so there is no strain on the hoses).
4) Remove and compare BOTH sets of brake pads. Compare like to like, i. e.: trail edge of left outer pad to trail edge of right outer pad, etc.
Are both sides EXACTLY identical, or are there differences? If there are differences, describe.
Is there sufficient piston standing proud of the caliper that you can peel back the dust boot and check for rust or gum on the piston?
Can you get a set of Channel-Loks onto the piston lip and rotate the piston within the caliper? If the pistons will rotate, does one rotate more easily than the other?
(There is one more test that is very effective in diagnosis, but if you are unsure of the date of last brake-fluid change, I will not suggest it.)
2013 Toyota RAV4 - 51,000 miles - Toyota 0W-20, Toyota filter
#3114876 - 09/04/13 05:14 PM Re: Seizing caliper? [Re: OVERKILL]
KrisZ Online   happy
Loc: Toronto, Canada
How are the pads looking, are the wearing evenly?
My focus had the same thing happen and pads were not wearing evenly and the pad material was not parallel to the backing plate. However the rotoras were also very rusty and you could see that the pads did not make full contact with them.
In any case, new pads and rotors fixed the issue.
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#3114877 - 09/04/13 05:15 PM Re: Seizing caliper? [Re: chrome]
OVERKILL Offline
I don't know if I can get new parts for it if I did. I'll probably just buy new ones from BMW if that's the case.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3114879 - 09/04/13 05:16 PM Re: Seizing caliper? [Re: heynow]
OVERKILL Offline
They were machined about 6 months ago easily, if not longer than that. The squeaking started the other day.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3114882 - 09/04/13 05:17 PM Re: Seizing caliper? [Re: Tegger]
OVERKILL Offline
Great advice, and thank you. I don't think I'll have time for that in the next few days however, as I have a VERY busy month coming up unfortunately frown
The car doesn't have a front central jacking point, so I'll have to jack up both sides and put the front on stands.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3114884 - 09/04/13 05:19 PM Re: Seizing caliper? [Re: KrisZ]
OVERKILL Offline
The pads and rotors look excellent and there isn't really any rust build-up either shrug
I'm thinking the caliper is hanging the piston out a bit causing the pad to "scuff" the rotor as it spins. Which would explain the resistance.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3114889 - 09/04/13 05:22 PM Re: Seizing caliper? [Re: OVERKILL]
chrome Offline
Given the cost of new calipers from BMW, it will be well worth the effort to troubleshoot this problem. Good advice from Tegger et al.
Also, might be worth taking off the disc and cleaning both mating surfaces (hub/disc) with a wire brush. If corrosion sets in between the surfaces, that will lead to symptoms similar to DTV.
#3114892 - 09/04/13 05:24 PM Re: Seizing caliper? [Re: chrome]
OVERKILL Offline
The mating surfaces are spotless (should have mentioned that in the OP, my apologies) and have already been cleaned recently.
Yes, the calipers are about $500/each.......... crzy
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3114912 - 09/04/13 05:44 PM Re: Seizing caliper? [Re: OVERKILL]
Astro14 Offline
Loc: Virginia Beach
In addition to the caliper checks above, it is possible that the brake hose itself has started to degrade internally, preventing free fluid flow when the piston should retract...in essence, acting like a one way valve...if the calipers check out, then I suggest changing front brake hoses and flushing the fluid...
32 Packard 15W40
90 4Runner 10W40 Edge
92 300E 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#3114920 - 09/04/13 05:49 PM Re: Seizing caliper? [Re: Astro14]
cb_13 Offline
Loc: Missouri
I agree with Astro. I have seen the hoses cause a similar issue. Even if you replace the caliper I would also replace the hose if it's a high mileage vehicle.
#3114921 - 09/04/13 05:50 PM Re: Seizing caliper? [Re: OVERKILL]
JamesBond Offline
Loc: midwest
If you drive it around the block easy a few times, is there a difference in temperature of the rotors after you park it?
I assume this is a special car that doesn't get driven daily. Find a safe place and give the brakes a bit of a workout and see if that helps.
I rebuilt a front caliper that had been dragging on an e28 535i recently. It was just cleaning the piston and bore, and replacing the seal and boot. The brakes had been bled recently but there was still a lot of gunk down in the caliper. I thought it would be difficult and was kind of timid about it but once you take it all apart its actually pretty simple. Watch some videos on how its done.
I would get a rebuild kit from BMW or from the caliper builder and give it a shot.
#3114924 - 09/04/13 05:55 PM Re: Seizing caliper? [Re: OVERKILL]
outdoorsman310 Offline
Loc: DE
when do you hear the squeak? low speed, high speed, affected by turning? do you hear it when applying parking brake instead of regular brake? check that the pads are worn evenly and the caliper and pads slide freely. the flex hose could be blocked inside as well. does that have tapered rotors? that has lug bolts instead of studs right? you might want to tighten a few on the rotor to ensure that it is flat on the hub when rotating the wheel.
