Are Cooper CS5 LRR?
by Stewart Fan
Today at 03:14 PM
Camry battery tested bad.
by chiefsfan1
Today at 03:08 PM
Electricly conductive grease for Samsung Galaxy???
by Drew99GT
Today at 01:40 PM
Right Oil and OCI for my Application?
by lancerplayer
Today at 01:06 PM
AZ card 20% off, AAP card 13% off
by gojoneeded
Today at 12:44 PM
NAPA (Flowers) Gold oil filter sale 9/5 to 9/10
by BigD1
Today at 12:38 PM
Japanese companies aren't as good !
by HTSS_TR
Today at 11:41 AM
Oil Viscosity Recomendation
by T_Bortz
Today at 11:35 AM
Clay, Polish, Wax OR Clay, Cleaner Wax
by SavagePatch
Today at 11:28 AM
VAICO Oil Filters
by tnt31
Today at 11:18 AM
Good oil and filter for hm 5.3
by Chevy538487
Today at 10:14 AM
At what timdo you consider your brake fluid "wet?"
by Bster13
Today at 09:34 AM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
90 registered (2015_PSD, 2009Edge, 2010Civic, AlaskaMike, 97f150, alarmguy, 5 invisible), 1606 Guests and 10 Spiders online.
58973 Members
66 Forums
253815 Topics
#3113894 - 09/03/13 06:38 PM ALL filters that fit HONDA via H, 20 x 1.5 mm
David1 Offline
Loc: USA, FLA
Im sure you all know how FRAM book says the part number is 3593A but the 7317 will fit also and looks more like the OEM filter at least the shape..... and as far as TOUGH GAURD its nearly identical other then the screen over the bypass.
Basically any filter that is H, 20 x 1.5 mm should fit the Hondas...
anyone see a list?
Basically I was wondering if other companies have something similar.
I know Baldwin does and Purolator does...
I mean even FRAM has more then 2
look
Fram TG3985 Tough Guard Oil Filter
FRAM TOUGH GUARD OIL FILTER -- 3.69 in. height, 20 x 1.5 mm thread ID
Anyone know of any others????
Looks like this page lists many Oil fitlers that have 20 x 1.5 mm Thread ID
http://www.autopartswarehouse.com/search/?N=0&Nr=AND%28make:Mitsubishi,part:Oil+Filter,universal:0%29&No=15&Npp=15
Hope link is Okay
For Fram 3593A its says for Mitsubishi.... weird huh?
Look at this FRAM that should fit
Fram High Mileage Oil Filter - Canister Part Number: FFHM3985 Manufacturer Number: HM3985
Fram Oil Filter Fram Oil Filter
More Images
add to compare
Fram Tough Guard Oil Filter - Canister Part Number: FFTG3950 Manufacturer Number: TG3950
FRAM TOUGH GUARD OIL FILTER -- 3.09 in. height, 20 x 1.5 mm thread ID, 3.66 in. OD, 2.42
Here is a LIST FOR HONDA ACCORD V6 and look how many differnt oil filters from the same company fit......
Long as its 20 x 1.5mm
Edited by David1 (09/03/13 06:46 PM)
2002 Honda Accord V6 3.0 Automatic Trans 203000 Miles
Valvoline Maxx Life 5W30
Purolator BOSS Or HONDA Filtech A01s
#3113904 - 09/03/13 06:49 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: David1]
David1 Offline
Loc: USA, FLA
This page is weird...
Look how many diff MOTORCRAFTS AND FRAMS AND other brands fit the HONDA, and Im talking diff part numbers.
http://www.autopartswarehouse.com/search/?refType=Sort+By&refValue=Price+High+to+Low&N=0&No=0&Nr=AND%28make%3AMitsubishi%2Cpart%3AOil+Filter%2Cuniversal%3A0%29&Npp=50&use_warranty_code_parent=AutoTrust&mvtgroup=B&Ns=price|1
#3113923 - 09/03/13 07:04 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: David1]
Sayjac Offline
Loc: The Old North State
Quote:
and as far as TOUGH GAURD its nearly identical other then the screen over the bypass....
As far as efficiency of A02 vs TG goes, not even in the same ball park and repeated posting of this inaccurate information won't make it so. Differences recently explained in this post. TG screen over bypass eliminated by Fram some time ago.
7317/14610 size is spec on all post 2002-03 Hondas, Civic started using it in 01. Pre 03 used larger diameter 3593A/14459. That said, the shorty 6607/14612 will also fit all, though not sure why anyone but the quickee lubes and some indy's would use them.
#3113924 - 09/03/13 07:05 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: David1]
gregk24 Offline
Loc: FL, USA
Everything I have seen says the 7317 is for Hondas.
2012 Honda Accord EX-L
Taffeta White - Ivory
40,xxx miles
PPPP 0w20 / Fram Ultra
#3113951 - 09/03/13 07:34 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: gregk24]
David1 Offline
Loc: USA, FLA
Really?
Look at FRAM site
Ill save you the Trouble.
Even ROCKAUTO says
Ill save you trouble also.
Even Wallyworld.. but I think you know what I mean.
here even AutoZone
There are many posts here that tell you that FRAM list the 3593a
Im surprised this is the first time you have not seen it.
Edited by David1 (09/03/13 07:38 PM)
#3113958 - 09/03/13 07:40 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: David1]
ZeeOSix Offline
Loc: PNW
You saw what sayjac said, right? It all depends on what car year you are talking about.
#3113976 - 09/03/13 07:57 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: Sayjac]
David1 Offline
Loc: USA, FLA
So what are you saying the TOUGH GAURD is the better filter compared to the HONDA OEM?
Also the screen over the bypass, I no longer see it on the FRAM site however each picture I see on Google shows it, but Ill take your word about that.
One of these days when I do a Oil change Ill try a TOugh Gaurd and cut it open after and compare to the 02
However I already have the next filter for my next OC, NIPPON FILTER
that is suppose to be the same as the A01 filter as you can see by the pic
they sell em on ebay
manufactured by Nippon for Honda
15400-PLM-A01 (replaced by 15400-PLM-A02)
Edited by David1 (09/03/13 07:59 PM)
#3114036 - 09/03/13 08:57 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: David1]
901Memphis Offline
Loc: Northern Kentucky
Yes the tough guard is better than oem Honda. It has a higher efficiency and better build with the silicone advice.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3114037 - 09/03/13 08:58 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: 901Memphis]
David1 Offline
Loc: USA, FLA
How do you feel about the A01 and the new A02s
What is your position on them?
WHat do you think is a better filter and why?
#3114108 - 09/03/13 09:56 PM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: David1]
ZeeOSix Offline
Loc: PNW
I think there was a pretty recent thread that compared the A01 and A02 filters. Might try the search function unless someone can dig it up fast.
A filter's brand name doesn't matter ... what's inside does.
#3114289 - 09/04/13 06:32 AM Re: ALL filters that fit HONDA via H, 20 x 1.5 mm [Re: David1]
Sayjac Offline
I'm saying the TOUGH GUARD is a much more efficient than the A02 which tested at a relatively very low [email protected] That's why some here refer to the Honda oems as 'rock catchers' either humorously or otherwise. If getting more efficiency for your dollar spent is important as it is for many here, then 'between the two' the TG would be the clear choice. And though I've seen no ISO test of the A01, based on the A02 rating and testing of similar no endcap type filters shown here, safe to say imo the A01 is no higher than the A02, if that.
Also the screen over the bypass, I no longer see it on the FRAM site however each picture I see on Google shows it, but Ill take your word about that.....
I'm gratified that you'll take my word for it, but a very recent Bitog thread (linked below *) comparing a A02 to a TG7317 verifies the fact that the screen is no longer used on TG filters, and that the current Fram website depiction is accurate.
Had you read my first reply the posting of all the different website information would have been unnecessary as the information regarding the use of the different diameter filters and applications was listed. They all have the same size gasket (within tolerance) so that's not an issue. The larger diameter 3593a/14459 will fit some newer spec 7317 Hondas including the 7th gen Civic's. They will not fit the 8th generation Accord though. But the 7317/14610 and shorty 6607/14612 will fit all Hondas including those spec'd for the 3593a/14459.
* TG7317 vs A02 Cut Open Pics.
