Patman
Staff member
What are all the specs on the Amsoil oil filter? What are it's multipass and single pass efficiency ratings, and the nominal and absolute efficiency? What about burst strength?
I assume you are talking about full flow filters. I have not seen figures for all the questions you ask. Have seen on one size with filtration effeciency of 94% per SAE HS806 (Mobil 1 and Pure One were 93%). I would like to see more independent tests, though.quote:
10 µmquote:
At what micron level is that multipass rating though? 10 microns? 15?
The OEM burst strength level is 150psi I believe, so that puts the Amsoil at 300psi I suppose. A good rating, but the Mobil 1 and K&N are in the 550-600psi range. Overkill perhaps, but it shows how thick the canister is so for someone who has a filter on the bottom of the engine and is worried about it getting hit by debris, the thickest filter you can buy is a good thing.
