Originally Posted By: JOD
Originally Posted By: stockrex
that video is [censored] just suction out all the fluid in the tank and add new fluid do it a few times...
Sure, if you want to waste both time and fluid, all while getting out less of the old fluid, do it your way...
Some systems are prone to getting air in them, but this car isn't one of them. You can do a full flush getting out almost all of the fluid in about 10 minutes on this car. Suctioning out the fluid is great for preventative maintenance on a regular basis, but when the fluid has been in there this long, getting it all out seems like a good idea to me.
Bad idea. Its better if the fluid has over 100000 miles to change it out a gallon at a time,every 1000 miles or so.
I can't say exactly why but when doing a complete flush on a tranny with questionable fluid changes I've always had problems develop,but if I change the fluid out in stages I've not had any tranny problems.
My friend has a shop. He is a tranny guy. He says if the fluid isn't changed before 100000 miles then don't change it at all. He says most of his business comes after the customer does some kind of super flush on a high mile tranny that hasn't had consistent maintenance.
He says they leak,the clutches and solenoids don't function properly.
Since its his business I believe him. His routine regardless of manufacturer is 50000kms drain and fills. If longer than that he says do a gallon at a time every 1000kms
