I don't hear alot about these filters. From what the box says they are part synthetic and part natural fibers. How do these filters compare to the rest of the ones out there overall?
Jason
Jason
I think it's safe to say that most of us on this board simply want to get that little bit extra engine life, even if we know people can still get 150k out of dino oil and cheap filters, there are those of us who simply feel better using the premium stuff, and perhaps getting 200-250k out of our engines.quote:
Originally posted by ssmokn:
I think it is safe to say that we can easily get 150K+ (and often many more) miles from any reasonably maintained engine just by doing "regular" maintenance.
Assuming you agree with what I said above, what is the point of spending $6 to $10 on an oil filter when a $2 Supertech will get you to the same end goal.
Patman is correct. Despite the high efficiency of the STP/SuperTech filters, it is rated for filtering 20 microns, the Bosch for 15 microns, and the Mobil 1 for 10 microns.quote:
Originally posted by Patman:
While the Supertech is good for the money, I don't believe it will filter out as many of the 15-20 micron particles as the Bosch would. And from what I understand, the Bosch premium filters are only about $6 or $7US? Not a bad deal compared to the $12 for the Mobil 1.
He should have used a good oil with longer intervals, then he wouldn't have wasted so much time sitting at the dealer.quote:
I have a friend (salesman) that purchased a '94 Grand Marquis in late '95 with 17K miles (came off lease). The dealer threw in free oil/filter changes every 3K as part of the deal. This vehicle now has almost 260K on the original motor (and still running strong). He could have bought Mobil 1 oil and filters (or Amsoil or Shaeffers or whatever) every 3K out of his own pocket but would he have been better off?
No argument there. I'm a believer, though I have yet to install one myself. Something about choosing between systems without seeing them makes it difficult. So I screw around with oversize full-flows & magnets & continue my hypocrisy. Point taken.quote:
My main point which seems to be missed by all is that if your REALLY concerned about filtration look at bypass filters not full flow...
Well, common sense says yes, it would last longer. However, there has never been a scientific comparison test of this hypothesis by any oprganization, manufacturer etc. so it is speculation on all parts.quote:
Originally posted by OneQuartLow:
ssmokn, Are you disputing that the same vehicle with better filtration/oil/maintenance would last longer?
David
