I have a 2013 Scion FR-S which I drive mostly as a daily but I intend to use for auto-x and HPDE upon occasion. The car takes 0W-20 stock from the factory, and as they cars run hot (and I live in Houston) I use both amsoil 0W-20 and a 13 row custom setrab oil cooler (thermostatically controlled).
I'm installing an oil pressure gauge to get a sense of my pressures with the oil at full operating temps (212) prior to hitting the track. There has been some concern on the FRS Forum at very high RPMs (7,000+) that oil pressure with a cooler is not sufficient (some owners have seen pressure readings in the low 60 PSI range) under "racing" conditions (high oil temps 250+). As a result, several FRS drivers who track regularly have stepped up to 0W-30 to "raise" oil pressure in these conditions. There is some concern also that the oil coolers create an additional pressure drop exacerbating the issue.
I'm not clear if I really need to run a heavier weight oil to attend HPDE events based on my research on this forum (I've read through all the oil 101 posts).
How do I take my oil pressure readings at 212f at various RPMs and extrapolate if my pressure will be sufficient at higher oil temps (250f+)? From my research, a 30 weight oil shouldn't be materially more viscous at temps in excess of 250f. In addition, while running an cooler does provide a small loss in pressure, shouldn't it be made up by the fact that the oil is cooler and therefore thicker?
I appreciate thoughts and feedback on the situation. I'm waiting on some additional parts to come in prior to testing my oil pressures which I hope to have this week.
