1999 Mercury Tracer wagon
When the car is parked, uneven, popping pulses from tailpipe and the engine dies when I turn a/c on.
All of this started with the ses light last week. Per Advance Auto hand held tester shift solenoid C malfunction code P0760.
What I have done:
new sparkplugs
new fuel filter
new battery
Visually checked transmission wiring harnesses connectors and plugs for damage, corrosion. All were clean.
Checked timing belt for stripped teeth, and alignment marks on gears. All was good.
atf does not smell burned
I am saving a transmission pan drop for last. If anyone can make a connection between the misfire and the transmission problem, and possibly a solution that would be a great help. Thanks!
What I have done:
new sparkplugs
new fuel filter
new battery
