Originally Posted By: Hokiefyd
Originally Posted By: badtlc
The base fuel is for reference, not the top tier fuels themselves.
Exactly. The additive package (and subsequently the fuel) can still be TT without ethanol.
I'm not sure I understand this. If the base fuel (upon which TT fuels are based) are required to have between 8 and 10% ethanol, how can additives "un-ethanol" the fuel? It says at the top of that page that "These standards comprise the requirements for TOP TIER Detergent Gasoline."
Maybe I'm not understanding the difference between the "base fuel" and the fuel sold at the retail level. Is the retail fuel not the "base fuel" plus retailer-specific additives?
The "base fuel" is the fuel without the detergent package. The detergent package is what makes the fuel "top tier".
You can deviate from the base fuel and keep the detergent package the same, subsequently maintaining the Top Tier compliance of the product, as it is the detergent package that is certified.
Make sense?
BTW, I'm basing this on these statements:
Quote:
1.3.1.2 Base Fuel. The base fuel shall conform to ASTM D 4814 and shall contain commercial fuel grade ethanol conforming to ASTM D 4806. All gasoline blend stocks used to formulate the base fuel shall be representative of normal U.S. refinery operations and shall be derived from conversion units downstream of distillation. Butanes and pentanes are allowed for vapor pressure adjustment. The use of chemical streams is prohibited. The base fuel shall have the following specific properties after the addition of ethanol:
Contain enough denatured ethanol such that the actual ethanol content is no less than 8.0 and no more than 10.0 volume percent.
Contain no less than 8 volume percent olefins. At least 75% of the olefins shall be derived from FCC gasoline as defined by CARB (advisory letter, April 19, 2001).
Contain no less than 28 volume percent aromatics as measured by ASTM D 1319 or D 5580.
Contain no less than 24 mg/kg sulfur as measured by ASTM D 2622 or D 5453. At least 60% of the sulfur shall be derived from FCC blend stock.
Produce a 90% evaporation distillation temperature no less than 290F. as measured by ASTM D 86.
Produce IVD no less than 500 mg averaged over all intake valves.
then:
Quote:
1.3.1.3 Demonstration of Performance. The base fuel from 1.3.1.2 shall contain enough deposit control additive such the IVD is no more than 50 mg averaged over all intake valves. Results for individual valves and an average shall be reported. The unwashed gum level of the fuel containing deposit control additive shall be determined according to ASTM D 381 and reported.
Quote:
1.3.2.3 Demonstration of Performance. The base fuel from 1.3.1.2
treated with additive at the concentration meeting the standard found in 1.3.1.3 shall not result in more than 140% of the average CCD weight for the base fuel without additive.
And then:
Quote:
1.3.3.2 Base Fuel. Two options for base fuel are available:
Quote:
1.3.3.2.1 Option 1. A full boiling range hydrocarbon gasoline or gasoline blending component,
without oxygenates and without deposit control additives, that results in at least five inoperative injectors when tested by the method in 1.3.3.1.
Quote:
1.3.3.2.2 Option 2. Federal emissions test gasoline specified in DFR 86.113-04, into which 4-methylbenzenethiol (WARNING: Flammable solid; irritant) has been blended at a concentration of 56 mg/L. The blended fuel must result in at least four inoperative injectors when tested by the method in 1.3.3.1. the Federal emissions gasoline, without deposit control additives, available from
Haltermann Solutions
15635 Jacintoport Blvd.
Stolt Building, Second Floor
Houston, TX 77015
800-696-2542
www.haltermannsolutions.com
