Originally Posted By: badtlc
Originally Posted By: Char Baby
So, I have a little different question but, still in regards to Mazda! I don't meant to hi-jack the thread so, forgive me if it seems this way. I just want to touch on the subject since it's still fresh in our minds.
I've been using Castrol IMV in my daughters '06 mazda3 2.0L with the 4 speed automatic tranny.
I change it about every 20K-25K miles. I will be changing the ATF again with IMV next month. This will be the 4th time that I've done a D&F since 2009 w/IMV. Should I be using Mazda M-V? The tranny shifts fine! And this 4spd is the nicest shifting tranny I've experienced in any of our 4 vehicles
Castrol IMF lists Mazda M-V as a spec it meets. IMF does have the higher viscosity required to meet the spec.
Does the 4spd spec Mazda M-V? For some reason I thought it was only the 5spd FNR5 that spec'd that fluid.
Well, the Owners Manual(OM) does recomend this but, I can't remember if the OM specified for one or both trannys. I do know that the M-V is the only mention of ATF in the OM.
Castrol Import Multi-Vehicle ATF lists both M5 & FNR5 fluid on its sheet as 'recommended for', whatever that's worth to you: http://www.castrol.com/liveassets/bp_internet/castrol/castrol_usa/STAGING/local_assets/downloads/p,q/pds_ImportMV.pdf
Somehow they're in the process of changing the name to Castrol Transmax IMV ATF, but it also lists M5 & FNR5 on its 'recommended for' list: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/064FD5179C8D0FFD80257AA90053687A/$File/Castrol%20Transmax%20Import%20MV%20_03521_.pdf
Yes, Castrol has already changed all of their ATF to the TransMAX name almost 2 yrs ago. I bought a boat load of this IMV for ~1.70/qt after tax & coupon prior to the TransMax changeover. I still have 2 D&F's remaining. and I've used 10 qts in other vehicles. I can't even remember how many qts that I bought. 30qts, maybe more!
