Removing original water pump from 2003 Toyota Echo following Toyota Maintenance manual procedure, removed pulley, then water pump bolts, separated pump body from block but the shaft and attached vanes are too long to clear car body frame and engine to remove.
Tried for almost an hour.
Is there a special trick to this?
Help Please.
Help Please.
