Lubrication Engineers vs Schaeffer's
by Dad2leia
05/04/16 05:49 PM
Tesla reports a worse than expected loss $282.3m
by Nate1979
05/04/16 05:27 PM
Using P/S fluid in a system that takes ATF ok?
by gregk24
05/04/16 05:24 PM
Redoing an old retrofit job headlights please help
by OtisBlkR1
05/04/16 05:19 PM
Mobil at Walmart + Mobil Rebate + Ibotta= $1/quart
by macarose
05/04/16 05:13 PM
Case 2470 tractor oil filters has slits
by njohnson
05/04/16 05:09 PM
Neglected Can Am Spyder
by Panzerman
05/04/16 04:22 PM
Considering a new Lexus ES - Durability?
by David_Corbett
05/04/16 04:02 PM
2016 Audi S4 Factory Fill UOA at 3,793 Miles
by CrazyJeeper
05/04/16 03:25 PM
epoxy to secure asphalt shingle?
by Digital2k2
05/04/16 03:21 PM
$75 Seized engine
by demarpaint
05/04/16 03:19 PM
Question on a VIN number..
by dblshock
05/04/16 03:18 PM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
95 registered (AandPDan, 69GTX, 1JZ_E46, Al, 11 invisible), 0 Guests and 1 Spider online.
57794 Members
66 Forums
248471 Topics
Page 1 of 7 1 2 3 4 5 6 7 >
#3094965 - 08/13/13 09:05 PM Canola Follow-up
KeMBro2012 Offline
Loc: California
I wasn't going to post this after the disaster the original thread turned into, but I just reviewed my PMs and have over a dozen requests for updates. I don't have time to update everyone individually, so it looks like I'm doing a follow-up thread anyway. I appreciate, in advance, the lack of personal attacks and name-calling, thank you.
So I haven't quite made it to 1500 miles on the 25% canola blend yet and I'll be dumping it and sending in a sample when I do. I also haven't driven much in the last 2.5 months, a total of maybe 50 miles in the 9 weeks leading up to last week, about 100 miles since then. Prior to parking it, the engine was running great, the oil seemed to have a lot of life left in it (I wish I had send in a sample at 1300 miles so I had numbers to back this up), smelled like motor oil, felt like motor oil, looked like good clean oil, engine running great. I'd posit that I could have run this oil to 6k, or farther, had I not parked it. When I have reason to drive more frequently again, I'll repeat the test and hopefully provide results to back that up.
Now the bad: Like I said, everything was going great until I let it sit and rot for over 2 months. Just before I started driving it regularly again (last week), the oil had begun smelling rancid, now feels a little thicker than it probably should, has darkened up a lot, I can tell it's oxidized quite a bit, and the engine is definitely running like it's due for an oil change.
This is all subjective, of course, since I haven't sent my sample in yet. No worries, that'll come soon enough; I want to run this oil up to 1.5k, which will happen tonight, first.
It is also important to note that this oil was put in on February 3rd, so it's a bit over 6 months old. A decent OCI for a vehicle that's been driven, and driven hard. I stress my engine and, by extension, my oil, with a heavy foot, frequent redline, and extended runs at high RPMs. I've had Mobil 1 graciously bow out ofter only 3 months of service and this oil was still going strong after 3.5, until I parked it.
My (inconclusive) analysis, at this point, is that canola is a good (I'd like to say excellent, but won't without numbers to back it up) additive for a daily driven vehicle, but horrible for a short-tripper or rarely-driven car. My basis for this is the consistency of performance and lack of apparent degradation, even under high-stress, high-load driving conditions, while I was frequently driving the car, coupled with the rapid deterioration of the oil when left to sit.
Would I run this again? Absolutely! And I will, when I have reason to drive it at least 3 or 4 time a week. My next fill, however, will be 4 quarts of 5w30 Royal Purple, which I know, from experience, will last much better in storage.
Don't bother jumping me for not posting a UOA; just stay tuned and you'll see it for yourself.
Thanks to all who were interested in this experiment and all who will take interest in my results.
#3094976 - 08/13/13 09:17 PM Re: Canola Follow-up [Re: KeMBro2012]
Rolla07 Offline
Loc: MTL, CANADA
Interesting! Look fwd to see the UOA!
2007 Corolla Red Pearl 134k miles
TGMO 0w20 & Toyota OEM filter
#3094978 - 08/13/13 09:20 PM Re: Canola Follow-up [Re: KeMBro2012]
Mystic Offline
Loc: Colorado
Heck yes do a follow up! What is wrong with you testing Canola oil? Maybe it will work better than the motor oils we are using today.
#3094982 - 08/13/13 09:23 PM Re: Canola Follow-up [Re: KeMBro2012]
Brule Offline
Loc: St. Louis, Mo
Vegetable oil even gummed up my hair clippers. It would never cross my mind to use it in a car's engine. I would be very interested in seeing the inside of that oil filter.
2014 Camry V6 SE (QSUD 5w20)
2003 Civic Si [sold]
2010 Frontier SE 4.0 [gone]
2006 BMW M Coupe [sold]
#3094996 - 08/13/13 09:41 PM Re: Canola Follow-up [Re: Brule]
KeMBro2012 Offline
Loc: California
It was only after much research and contemplation that I decided to try this. I used a very stout oil (Rotella T6) as a base and only mixed in 25% canola; running 100% just wasn't in the cards for me.
Some of the uses canola has seen (military service -- and not for cooking -- and as a heavy machinery lube) are much more demanding than the inside of your typical engine. These are constant-use, minimal-maintenance scenarios, which seems to coincide with my experience; this oil seemed like it was gonna last dang near forever until I stopped using it for a while.
I'll keep everyone posted for sure. smile
#3095007 - 08/13/13 09:56 PM Re: Canola Follow-up [Re: KeMBro2012]
Mystic Offline
Loc: Colorado
This is something fresh and interesting. What a relief getting away from the typical Auto-RX-Kreen-MMO discussions. Not that I mind discussing Kreen and MMO but it is nice to hear about something new. And I had no idea Canola oil was being used by the military, etc.
#3095054 - 08/13/13 11:50 PM Re: Canola Follow-up [Re: KeMBro2012]
MrQuackers Offline
Loc: Oregon
I was hoping you would come back!
As iron sharpens iron, so one man sharpens another
coffee Brawndo's got electrolytes!
Change your oil every 3k-5k
-AEHaas
#3095082 - 08/14/13 01:26 AM Re: Canola Follow-up [Re: KeMBro2012]
zloveraz Offline
Loc: Frisco, TX
Did you ever get a VOA of this mix?
We need a jazzy name for this concoction as we can't allow "Caterham blend" to have all of the spotlight. How about RoNula blend or Kembro C6 or Cantella? shrug
11 G37S, QSUD, microGreen MG101-7
14 BMW F800GS Adventure
#3095094 - 08/14/13 04:05 AM Re: Canola Follow-up [Re: KeMBro2012]
demarpaint Offline
Loc: NY
That's good! I was hoping you didn't scrap the idea of updating us.
God Bless Our Troops
#3095100 - 08/14/13 04:59 AM Re: Canola Follow-up [Re: zloveraz]
KeMBro2012 Offline
Loc: California
Nope, no VOA, I wasn't thinking that far ahead. When I revisit this after my next OCI, I'll send in a VOA sample, so we have something to compare with. I also plan to drive at least 30min/day and send in a sample every 1500 miles next time. I guess I'm sticking with the sample every 1500 miles this time around, too, just draining at the first interval.
Which... by the way... I fell short of by approximately 5 miles tonight. That should leave me enough mileage to get the engine warmed up before I drain it. smile
As for the name, if we want to stay true to the makeup of the oil, Brassica T6 (Canola is made from a specific strain of rapeseed, or Brassica napus) sounds good to me. Using the genus and species spares us the negative connotations that would be associated with the common name, which would have lead to Rapetella C6, or another even more off-color name that's too risque for this forum (hint: ****lube).
Ahem... Brassica T6. I like it.
Of course, I'd like to make sure it's worthwhile before I get attached to it enough to officially name it. smile
#3095126 - 08/14/13 06:28 AM Re: Canola Follow-up [Re: zloveraz]
GreeCguy Offline
Loc: Elderly County, Florida
I vote of "Cantella."
I'm surprised that the oil went rancid. I was thinking with a 25 percent mixture that the 75 percent regular oil would kill any bugs that decided to dine on the 25 percent veggie oil.
I have two electric hair clippers and use olive oil to keep them lubed. One set gums up from time to time while the other has never given me a problem.
I have used USED cooking oil, (filtered before I used it) as a bar and chain lube for my chain saw which gummed up within minutes of operation. Using FRESH cooking oil however has given me no problem at all.
What I would like to see during this experiment would be the inside of the oil filter and the valve covers removed. If it's possible, drop the oil pan as well and see what the pick up on the oil pump looks like.
"Dyslexics are teople poo!!."
#3095277 - 08/14/13 10:09 AM Re: Canola Follow-up [Re: KeMBro2012]
Nate1979 Offline
Loc: Portland, OR
My understanding is that vegetable oils, like canola which contain unsaturated carbon chains are unstable and prone to oxidation. Time, oxygen, and heat are the enemy and will turn the oil rancid.
2015 GMC Sierra 2500 6.0L Factory fill
2010 Subaru Forester 2.5X QSUD 5w-30 w/ Fram Ultra
#3095302 - 08/14/13 10:33 AM Re: Canola Follow-up [Re: KeMBro2012]
friendly_jacek Offline
Loc: southeast US
Many thanks for the update. As you may remember, I posted a link to a study in Postal vehicles where they used vege oil based lubricants. It worked great except for one thing: short OCI.
I guess you came across the very same limitation.
I guess those omega fatty acids are not good for engines.
#3095375 - 08/14/13 12:04 PM Re: Canola Follow-up [Re: KeMBro2012]
KCJeep Offline
Loc: Mahzurrah!
Great stuff, thanks for the update! Looking forward to further testing results and your UOA.
2004 Jeep Grand 4.0 @ 132k Pennzoil HM 5w30 w/ 1 qt 10w40
Fram TG8A
KIA Sedona 57k, Ford Focus 114k, Chrysler Sebring 184k, Chrysler Concorde 115k
#3095381 - 08/14/13 12:14 PM Re: Canola Follow-up [Re: KeMBro2012]
jhMalibu Offline
Loc: Boston, MA
I appreciated your willingness to try new things and didn't understand why people got so crazy.
Could you dope the RoNula (I like that one) with LC20 to slow down oxidation?
