CJ-4 Synthetic Oil for Kawasaki FX engine?
by lawnguy
02/11/16 06:54 PM
Body was there for months......
by OVERKILL
02/11/16 06:23 PM
Promotive by Purolator ph241/pl10241 13 months/10k
by Xrs2zz
02/11/16 06:01 PM
Who had a small GM diesel?
by OVERKILL
02/11/16 05:40 PM
Rotella 5W40 in a Tecumseh
by TriMoto
02/11/16 05:36 PM
GM 6L45R Auto Tranny - Change Fluid @ 190k?
by zeddy
02/11/16 05:18 PM
the "search" feature is terrible
by nicrfe1370
02/11/16 04:38 PM
API SN / ILSAC GF-5. Taking a shellacking
by wemay
02/11/16 04:37 PM
Got the air compressor - now what else do I need ?
by Cressida
02/11/16 04:19 PM
Cold today bad battery
by bprat318
02/11/16 04:05 PM
Blending 15w-40 + trying to get it to ~10w-30 ?
by Cressida
02/11/16 03:57 PM
I'll never remove my trailer hitch again
by grampi
02/11/16 03:40 PM
SkipKaye, MikeHancho, tempnexus, cobra1616z, meyer
56896 Registered Users
109 registered (2KBMW, 97f150, 901Memphis, 6X13, 90crvtec, alcyon, 12 invisible), 1604 Guests and 202 Spiders online.
56896 Members
66 Forums
244566 Topics
#3039185 - 06/20/13 06:30 AM ISO VG 32
pwhittle Offline
Loc: Alpharetta, GA
I just took delivery of a hydraulic scissor auto lift that calls for 1 gallon of ISO VG 32 hydraulic fluid.
I see Advance Auto carries Shield AW 32 in one gallon jugs.
Is this an acceptable substitute?
I also have access to a Tractor Supply and NAPA locally.
Thanks in advance.
Paul
#3039768 - 06/20/13 04:29 PM Re: ISO VG 32 [Re: pwhittle]
MolaKule Offline
Loc: Iowegia - USA
As long as it is an ISO 32 Anti-Wear fluid with about a 5.5 cSt viscosity @ 100C it should work.
http://www.bobistheoilguy.com/viscosity-charts/
http://www.hfifluidpowerproducts.com/Pages/Hydraulic-Fluid.html
I just ordered a chicken and an egg from the Internet; will let you know which came first. smile
#3040141 - 06/20/13 10:40 PM Re: ISO VG 32 [Re: MolaKule]
pwhittle Offline
Loc: Alpharetta, GA
Thanks MolaKule!
#3040781 - 06/21/13 01:56 PM Re: ISO VG 32 [Re: pwhittle]
TMoto Offline
Loc: CO
My old Hangsterfer's chart lists the following that may be helpful.
Hangsterfer's AW32
Mobil DTE 24
Texaco Rando HD 32
Shell Tellus 32
Exxon Nuto H 32
Castrol Hyspin AW 32
Chevron AW HYD 32
Union UNAS AW32
#3041229 - 06/21/13 09:24 PM Re: ISO VG 32 [Re: pwhittle]
MolaKule Offline
Loc: Iowegia - USA
Or Schaeffer's #254 HTC Supreme ISO 32.
Edited by MolaKule (06/21/13 09:24 PM)
#3068073 - 07/17/13 12:43 PM Re: ISO VG 32 [Re: pwhittle]
camelCase Offline
Loc: Southeastern, USA
SLFI also makes some great hydraulic fluids. They are my go-to for unique fluids. Their anti-wear in a Iso32 should do the trick for you.
http://www.slfi.net/mineral-oils/hydraulic-oil
#3091277 - 08/09/13 10:22 PM Re: ISO VG 32 [Re: pwhittle]
bruce381 Offline
Loc: Millbrae, CA
accually hydrualic fluid viscosity as in VG 32 ia run at 40C not 100c as such any ISO VG 32 oil will be a 32 oil not withstanding any additve or oil type differences.
Industrial gear oils are aslo run at 40C where automotive axle lube are at 100C
#3091959 - 08/10/13 07:18 PM Re: ISO VG 32 [Re: pwhittle]
Shannow Offline
Loc: Oz
bruce, not to nitpick, and maybe subject of another thread...
Have had experience with some 12,000 Voith turbo-couplings, and a previous engineer swapped them to BP "HV"32, a high viscosity index 32 in the past.
Quickly it became a 24-26 as the VIIs were beaten out of it.
#3092928 - 08/11/13 09:20 PM Re: ISO VG 32 [Re: Shannow]
bruce381 Offline
Loc: Millbrae, CA
yeah there are "low shear VII's" but they will still shear, even a non VI or newtonian fluid can shear given long enough.
I would rather up the vis grade 1 or use a GPIII with a higher VI but then sludge can be an issue.
Edited by bruce381 (08/11/13 09:21 PM)
#3093206 - 08/12/13 08:21 AM Re: ISO VG 32 [Re: pwhittle]
camelCase Offline
Yeah shear and pressure will do a number on viscosity. High grade POE and synthetic hydrocarbon based fluids can perform really well if the blender is using a good, shear resistance, additive. Granted - all fluids will degrade, it's a matter of how long it takes for it to get there.
