Originally Posted By: dnewton3
Originally Posted By: FZ1
Oil is done. 10k max.
What leads you to say that?
I see nothing in this report that indicates oil is "done". To the contrary, everything looks good. Wear rates are low, contamination low, vis OK. TBN is low, but that is to be expected. We would need to know the TAN also, before having a better view of the lube. Without knowing TAN, I cannot assure you that it's safe to go further, but then again neither can anyone assure this lube is "done" either. What we do know is that the wear rates are admirably low, and therefore we can presume acid is not acting on parts yet.
Nice to see someone actually extend a syn OCI, rather than run 4k miles and dump it.
I will note that for contrast, you might consider a conventional lube to see how well it would also perform. Your driving style is very tame and probably isn't going to really harm any lube, regardless of base stock.
The oil has thinned from 8.9 to 7.12...The flashpoint is down from 446 to 360...The tbn is low... The insoluables,probably,soot is .4...So I would leave a little margin for error and dump it at 10,000.
