Well, when they're 9 years old...
I'm going to start upgrading one item at a time. It is a 2004 Chevy Silverado Ext. cab. It has the steering wheel controls as well.
The door speakers are 6.5", and the speakers for the extended cab are 4x6's. That's all that it has right now. I am willing to do minor mods, but I'm not going to cut the truck up over this.
I've blown the driver's door speaker. Looking at these right now. These will install by redrilling the mounting holes in the door.
http://www.amazon.com/gp/product/B00A0LYU2S/
This is a 4 way speaker. Pioneer sells the same speaker in a 3 way model. Is a 4 way overkill? The way that GM has this truck set up, these are the speakers that are doing the most of the work, and I assumed a 4 way would be the way to go. Am I wrong?
Next would be the rear door speakers.
http://www.amazon.com/gp/product/B00A0M0PXA/
At this point, I have $110 invested in speakers, adapters, and foam speaker baffles for the rear speakers.
Head unit would be after that (along with the $50 adapter to reconnect the steering wheel controls). I'd like to use a double DIN unit to keep it the same size in the dash. Are there any drawbacks to that strategy?
Right now, this is the head unit that I'm considering:
http://www.crutchfield.com/p_113DPX500B/Kenwood-DPX500BT.html
Along with the head unit, I'd make provisions (run the wiring) to add a future sub box under the seat in the extended cab area.
I'll be doing all of the labor myself, and at this point, I've spent a little less than $400.
The head unit will need an aux input for my XM Roady 2 satellite radio.
So.... where am I making my mistakes? It has been 20 years since I've put an aftermarket car stereo in. Some things have changed, but some are still the same.
