This may not be the best place to post, but the marine forum doesn't seem to address small diesels.
I have a sailboat with a 1981 Yanmar 2QM15 diesel (2 cylinder, 15 HP). Engine is raw water cooled, so full operating temperature is only 125F. I sail in the Puget Sound, so temperatures are fairly moderate year round (30F - 90F most of the time).
Shop manual specifies straight weight oil, as follows:
50F - 60F: 20 weight
60F - 95F: 30 or 40 weight
>95F: 50 weight
Manual also specifies API CD oil. CD oil appears to be obsolete, but I've come across some discussions on the web that state that newer oils can be detrimental to small, low temperature marine diesels like this, primarily because of the high TBN value (apparently, small raw water cooled marine engines don't generate enough acids to offset the high TBN in modern oil, so the resultant alkalinity of the oil causes its own set of problems).
Any advice regarding oil selection? 15W40 seems to be in the sweet spot for viscosity, but the API CD thing has me stumped.
>95F: 50 weight
