Amsoil OE 15w40, 5K, 08 Ford F-250
Texas
Owner maintained 5k mile interval as advised by Blackstone on this first fill of Amsoil OE. Oil was dumped at time of test and refilled with Amsoil OE once again.
Make/Model: Navistar 6.4L V-8 Power Stroke Twin Turbo
Vehicle: 2008 Ford F-250
Code:
OIL OED 15w40 Rotella 15w40 Rotella 15w40
MILES IN USE 5014 5049 5935
MILES ON UNIT 62K 57K 52K
SAMPLE TAKEN 7/20/13 2/18/13 9/8/12
MAKE UP OIL 0 0 0
ALUMINUM 20 45 28
CHROMIUM 1 2 2
IRON 24 49 47
COPPER 1 1 2
LEAD 2 1 4
TIN 0 1 0
MOLYBDENUM 7 9 17
NICKEL 1 2 1
MANGANESE 0 1 1
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 2 10 10
BORON 26 23 24
SILICON 3 6 5
SODIUM 4 4 5
CALCIUM 2257 1837 1531
MAGNESIUM 20 85 257
PHOSPHORUS 969 833 805
ZINC 1131 942 912
BARIUM 0 0 0
SUS @ 210F 59.2 64.5 60.0
Visc @ 100C 9.99 11.46 10.21
Flashpoint 380 385 360
Fuel % 3.0 2.5 5.5
Antifreeze % 0.0 0.0 0.0
Water % 0.0 0.0 0.0
Insolubles % 0.3 0.3 0.4
Blackstone comments:
Fuel dilution is still present, and that's bringing the viscosity down a bit, but at least wear metals look pretty good. Aluminum dropped down into the average range, and iron is quite a bit better than it has been. The fuel isn't exactly what we like to see, but as long as you're not seeing the oil level rising, it might not be something that requires any immediate attention. If you're idling a lot, or the engine sees other low RPM use, maybe that's why all the fuel is present. No coolant, water, or excess dirt was found. For now, use this interval due to all the fuel.
The iron does not look right. I would not expect using Amsoil OE diesel oil to cut the iron in half. Rotella T is probably as good or better oil than Amsoil OE.
TBN?
Oxidation?
Thanks for sharing.
I'm not really worried about TBN at a 5k interval. Blackstone's basic test doesn't include oxidation.
Apparently not in the case...
