I'm pretty happy with both Castrol Ti and PU. I think there may be some variance due to season though: the first run of Castrol Ti is all summer use, seeing high temps. Second run was the following Fall through Spring, and looks real good, but didn't see a lot high temps. Then in the summer I switched to PU, but forgot to sample it when I changed last Fall. That ran until now, so 9 months and half the summer. I drive it like it was meant to. No tracking yet, was hoping to get a track record with oil first and make sure it isn't an oil burner (it isn't).
As far as "oil destroyer" I think it is (look at the Nissan Ester sample) but PU and Castrol Ti are pretty good oils IMHO.
