Blackstone comments: This is the first report we've seen where copper is at average, so that's good. It's also the first time iron's been out of line, though. Iron comes from steel parts in the engine enduring excess wear. We're not sure what could be causing that, but hopefully it's a temporary thing as a result of something operational. If so it'll come down next sample. No contamination was found in the forms of fuel, water, or coolant. The TBN read 1.5, showing some active additive remaining. A 12,000 to 13,000-mile run should be fine for Schnooky!
Note: Copper was 17 last time and 56 the time before.
Miles on oil: 10,167
Miles on Unit: 110,167
Makeup oil: 0 qts
ALUMINUM - 4
CHROMIUM - 0
IRON - 21 (FLAGGED)
COPPER - 6
LEAD - 3
TIN - 0
MOLYBDENUM - 45
NICKEL - 3
MANGANESE - 1
SILVER - 0
TITANIUM - 0
POTASSIUM - 0
BORON - 210
SILICON - 10
SODIUM - 5
CALCIUM - 2663
MAGNESIUM - 13
PHOSPHORUS - 771
ZINC - 749
BARIUM - 0
SUS Viscosity @ 210°F - 57.7
cSt Viscosity @ 100°C - 9.57
Flashpoint in °F - 390
Fuel % - Antifreeze % - 0
Water % - 0
Insolubles % - 0.3
TBN - 1.5
Oil was in for 9 months and I used a Mobil 1 oil filter.
This oil had a hard life. I lived 1.5 miles form work over the winter so this had several very cold starts. I tried to let it warm up 5+ minutes if it was below about 30 degrees. Coming home it saw cold starts and cold shut downs. Because of this, I wanted to sample and see where it was at.
The copper is down. I always suspected the copper was due to the copper oil cooler. The elevated iron concerns me a bit. I can say that when I opened the filler cap on the valve cover, there is a steel baffle that had a considerately larger amount of rust on it after this run, which I'm sure is due to condensation. I'm wondering if this isn't the iron source.
Overall I'm impressed with the PU and disappointed it's getting harder to find.
Comments welcome!
Makeup oil: 0 qts
ALUMINUM - 4
CHROMIUM - 0
IRON - 21 (FLAGGED)
COPPER - 6
LEAD - 3
TIN - 0
MOLYBDENUM - 45
NICKEL - 3
MANGANESE - 1
SILVER - 0
TITANIUM - 0
POTASSIUM - 0
BORON - 210
SILICON - 10
SODIUM - 5
CALCIUM - 2663
MAGNESIUM - 13
PHOSPHORUS - 771
ZINC - 749
BARIUM - 0
Water % - 0
Insolubles % - 0.3
TBN - 1.5
Comments welcome!
