Originally Posted By: MINick
Thanks a lot, i know the oil pump components, i just don't know if it's a bypass valve that will start bypassing oil at a given pressure, or a regulative valve, so i linked the pic in case you can tell.
When i built the engine, i tried to source wider gerotors from other pumps that could possibly fit, but found nothing unfortunately, and there's nothing available in the tuning market. I would possibly have wider gerotors made, but then comes the real hard stuff, to widen the case..
Ah haha, so you know what you're doing, sorry for wasting all of our time. Had I only clicked the link
Well hopefully someone got something out of it.
Anyway, in the parts list, it's termed "Control Valve", because it controls pressure and happens to do that by bypassing oil. It's a "bypass regulator" that begins to operate at a certain point. That point, is not as high as one may imagine. Therefore bypass as a "mode" is almost always happening. Just imagine 2000cSt cold oil vs 10cSt hot oil and you never see more than 70-80psi(eg) on the gauge. The valve obviously needs a wide ranging orifice (regulative capacity). The valve begins opening as pressure builds on the gauge- for example 3K+ at full hot rec. viscosity. Anything colder * anything thicker, and that baby is open, even if a little bit. The maximum pressure you see is not the magic opening point, because that changes with actually viscosity. Many times some oil pumps can put out pressures higher than their design pressure due to an inadequate bypass channel, and a person may be led to believe that this is their bypass pressure when that bad boy started opening up long ago. But some people like 100+psi cold on their gauge.
Internal leakage, cavitation all good considerations.
Shan's, too right that a thinner oil would leak internally more.
How much more? Anyone wanna to calculate this using pump displacement and measuring output volume? An equal increase in leakage on the delivery side might help balance that out
MINick, you should examine the control valve bore on your oil pump, I noticed it's stepped, three times, is there a secondary bypass channel?
