I would like to comment here, but my comment is for several subiects in adds section. First is for Mystic and others testing oil or adds for effect. I think almost all oils with a good amount of Calcium based detergents and dispersants, or Magnesium based detergents will be cleaning an engine at a similar rate. What matters more is how the viscosity of the oil allows fast flow rates and how fresh the oil is. Any of the good HDEO, HM or expensive synthetics will clean away sludge if you keep OCI short.
I think cleaning light varnish is silly idea, only heavy varnish from too high temperature or bad oil in turbo feed lines is big problem. If you clean all varnish from old engine I think you cause corrosion and oil leaks risk to increase. Mystic is right that part anyway.
Tests are fun but bottom end or turbo feed much more important for pictures and I don't understand why Bitogers pay any attention to adverstising, because when you compare cleaner adds you will have a different result for different engines and even for same engines their different block condition will give a different result. The temperature the engine is at during test and actual kinematic viscosity will change result.
Wear factrs go up when using lots of detergent or solvent in big way sometimes. This is because old AW and EP layers dissolved faster than deposited with new oil.
I have got rid of sludge with some engines just by using cheap oil on offer and changing it when black, which for bad engine is not long.
No real cause for adds to get rid of sludge and trying to get rid varnish could be big mistake I think.
