Shell Helix Ultra 5W-20 in Australia
by SR5
07/01/16 03:03 AM
Little different lube regimen on my 454
by Alex_V
07/01/16 03:00 AM
REPCO oil sale this weekend in Australia
by SR5
07/01/16 02:58 AM
ALG Go-Juice
by Ws6
07/01/16 02:55 AM
Stupid ? 20hp Intek b&s
by southernjeeper
07/01/16 02:23 AM
Mouse Guns
by bobbob
07/01/16 02:14 AM
Grease for gun
by DARKSCOPE001
07/01/16 01:44 AM
Walmart ST Full Synthetic 5W30 & 10W30 5QT $12.00
by Jonny5alive
07/01/16 01:11 AM
Keep America's Nuclear Power Stations Running
by Shannow
07/01/16 12:14 AM
Lubegard Biotech,my thoughts
by Marco620
07/01/16 12:03 AM
Frivolous lawsuit loser pays court cost !
by HTSS_TR
06/30/16 11:49 PM
cold seizure on a small air cooled engine?
by motor_oil_madman
06/30/16 11:20 PM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
27 registered (Alex_V, CharlieBauer, Black_Thunder, car51, 3 invisible), 813 Guests and 11 Spiders online.
58332 Members
66 Forums
251075 Topics
Page 2 of 2 < 1 2
#3080163 - 07/29/13 06:11 PM Re: Cleaning my intake? [Re: Staleembrace]
Staleembrace Offline
Loc: Mississippi
Lol autocorrect did me wrong I suppose. Meant about not a bong lmao
1995 Chevrolet Monte Carlo Z34 Coupe with 3.4L DOHC VIN code X
#3102664 - 08/22/13 03:06 PM Re: Cleaning my intake? [Re: Staleembrace]
camelCase Offline
Loc: Southeastern, USA
Look for a orange scented cleaner. These use D-Limolene as their base solvent and will absolutely DESTROY any carbon/varnish deposits.
#3265055 - 01/30/14 04:51 PM Re: Cleaning my intake? [Re: Staleembrace]
Spetz Offline
Loc: Australia
Would there be any real benefit of cleaning an intake manifold?
Either measurable in any way, or perceived?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 130,000 miles
#3265123 - 01/30/14 05:56 PM Re: Cleaning my intake? [Re: Spetz]
Clevy Offline
Loc: Saskatoon canada
Valve deposits removed creating a more complete seal potentially I proving compression.
And sucking it in through a couple different vacuum lines seems to help the engine feel more responsive with light throttle inputs.
OP. If those deposits are from the oil mist and combustion gasses that got by the rings then try using mmo or a 2 stroke oil.
My grandpa always said "like dissolves like" which can be translated as 2 similar based things will mix,meaning the cooked oil vapour should get soft and come loose if you add oil to it.
Try soaking a shop rag with 2 stroke oil or mmo and left it sit on top of the deposits overnight.
I had hard carbon deposits on the old pistons from my Harley and they were sitting on my table in my shop.
I accidentally spilled either mmo or 2 stroke oil and some of it got on the carbon encrusted pistons.
I went into my shop a few days later and saw the piston that got spilled on the carbon looked kinda soft,and I wiped the piston clean ONLY where the oil got spilled,the rest of the piston was still hard crusted carbon.
So on one piston I coated the entire top with mmo,the other one with 2 stroke oil and left them sit. The next evening I go to check them out and on both pistons the deposits came off however the mmo one was much softer and easier to clean. The 2 stroke oil one was a bit harder to clean off.
So I know these products will clean up hard,baked on,cooked deposits if given time to absorb into the affected area.
After seeing what they did to the insane build up on my Harley's stock pistons I began using mmo in the same fashion as seafoam,administering through a vacuum line trying to saturate all the deposits possible.
With mmo I stall the engine pouring it in as fast as it will accept it then once stalled let it sit for 20 mins to a half hour then take it out and drive spiritedly.
I think the best way is overnight though.
2006 Charger RT
Miles x 2 per oil filter
#3299943 - 03/03/14 08:14 AM Re: Cleaning my intake? [Re: Staleembrace]
ac_tc Offline
Loc: sweden
Mopar Combustion Chamber Cleaner
Google it
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3340140 - 04/11/14 07:47 PM Re: Cleaning my intake? [Re: Staleembrace]
xxch4osxx Offline
Loc: Cedarbrae, Ontario
Amsoil Power Foam works wonders on those deposits.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
#3347530 - 04/19/14 04:54 PM Re: Cleaning my intake? [Re: Staleembrace]
andyd Offline
Loc: Marshfield , MA
Heh heh Thanks Clevy, MMO is 1/4th the price of Seafoam and smells better too. I wonder if Demarpaint has used it in this fashion?
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
Page 2 of 2 < 1 2
