New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
Base Oil Content and Marketing
by MolaKule
05/28/16 03:08 PM
Best OTC fuel injector cleaner
by 007
05/28/16 03:06 PM
A brief BMW R1100RT story
by Finn
05/28/16 02:29 PM
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
05/28/16 12:51 PM
Caliper question
by supton
05/28/16 12:48 PM
Impressed with Yokohama Geolander A/T G015
by K20FA5
05/28/16 12:13 PM
Need a good tire pressure guage that read over 60
by MetalSlug
05/28/16 11:55 AM
Castrol 0w40 vs M1 0w40 FS ?
by Ndx
05/28/16 11:14 AM
what old Snapper parts to save
by edwardh1
05/28/16 10:56 AM
Interesting lunch hour
by Urshurak776
05/28/16 10:10 AM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
82 registered (87sammy, 2015_PSD, 2KBMW, 2K2AcuraTL, 340six, 04SE, 8 invisible), 1771 Guests and 321 Spiders online.
58001 Members
66 Forums
249529 Topics
Page 1 of 2 1 2 >
#3079323 - 07/28/13 09:39 PM Cleaning my intake?
Staleembrace Offline
Loc: Mississippi
Well I've got the throttle body off and the intake manifold off and I'm down to the gaskets. My intake has some black buildup and I'd like to remove this easily without a trip to the store again. After using a can of brake cleaner I had zero luck. It's pretty thick residue. Any tips?
1995 Chevrolet Monte Carlo Z34 Coupe with 3.4L DOHC VIN code X
#3079327 - 07/28/13 09:41 PM Re: Cleaning my intake? [Re: Staleembrace]
racer12306 Offline
Loc: Baltimore, MD
Metal or plastic intake manifold?
04 Dodge Neon SXT/2.0/MTX/PUP 5w20/Fram Ultra/5000 miles for now
12 Chrysler T&C/3.6/6A/5w30PU/PureONE/OLM
#3079336 - 07/28/13 09:51 PM Re: Cleaning my intake? [Re: Staleembrace]
Loc: Mississippi
It's metal. Here's what I'm trying to get clean.
Ps don't mind the rip in the gasket. Was an accident and a new one is going on tomorrow.
http://i.imgur.com/YcKqGCY.jpg
http://i.imgur.com/jArXfR5.jpg
I'm not too concerned with the external cleanliness as much as the interior. It looked baked inside there.
#3079337 - 07/28/13 09:53 PM Re: Cleaning my intake? [Re: Staleembrace]
71Chevyguy Offline
Loc: Martinsburg West Virginia
I was cleaning my TDI intake (aluminum) with brake cleaner and I was really surprised that it barely cleaned anything. I then switched to the Valvoline brand Throttle body cleaner and it almost instantly dissolved right down to the shiny metal. Not saying this is the best stuff, I just bought that one since it happened to be on sale. As well as it worked, the next time I think I will be buying it again regardless of price.
15 Chevy Sonic RS QSUD / Delco filter
85 Buick Skylark 2.5 VNGHM / PF52
87 Caprice 305
71 Nova 250
#3079338 - 07/28/13 09:54 PM Re: Cleaning my intake? [Re: Staleembrace]
yonyon Offline
Loc: NJ, USA
If it's a metal intake use a rag soaked with your cleaning solvent of choice or a brush, then spray to get rid of any loose fibers. Then again, it it's metal it might also be a rough casting. If so, you might be better off leaving that carbon in there to give a smoother surface and slightly better flow.
#3079340 - 07/28/13 09:58 PM Re: Cleaning my intake? [Re: Staleembrace]
Loc: Mississippi
It's rough casting externally but I'm pretty sure it's a smooth finish inside underneath the gunk. Somehow my throttle body is near spotless yet my intake looks like its loaded with tar lol. Is there any soak I can do to it overnight to just spray it down with a hose in the morning? There's a tiny o ring on top that's already kinda iffy that I'd rather not harm though. I don't plan to own the car but for another 3 months or so. If its not an issue ill just leave it alone.
#3079355 - 07/28/13 10:11 PM Re: Cleaning my intake? [Re: Staleembrace]
wally6934 Offline
Loc: Wi
A picture of a black hole does not help much. My plenum had a very dark black film on it and i just left it, i think it is the oil streak from the PCV valve.
Now if it is a thick layer of crud that is different.
#3079360 - 07/28/13 10:17 PM Re: Cleaning my intake? [Re: Staleembrace]
Loc: Mississippi
Ill get another pic after I'm done watching dexter. Sorry it's tough in pitch dark in the country with an iPhone lol
#3079361 - 07/28/13 10:17 PM Re: Cleaning my intake? [Re: Staleembrace]
jfking106 Offline
Loc: GA
http://www.lastotallyawesome.com/html/Products_Degreaser.html
$1 for the spray bottle, $3 for the big bottle at Dollar General. Buy a plastic tub you can submerge it in if you don't have one, soak it for 30 minutes in 50/50 cleaner and water. Rinse if off, then clean what's left with straight cleaner and a tooth brush.
Check out my thread in the solvent forum:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2949569#Post2949569
#3079420 - 07/28/13 11:32 PM Re: Cleaning my intake? [Re: Staleembrace]
Loc: Mississippi
http://i.imgur.com/fY0M4eY.jpg
That's a better shot of the inside. I don't think it's considered too bad but I don't like it. I'm planning to get rid of the car in like 3 months anyways so if its not an issue ill just skip it. Would any other cleaner work in place of the LA's totally awesome?
#3079424 - 07/28/13 11:41 PM Re: Cleaning my intake? [Re: Staleembrace]
yonyon Offline
Loc: NJ, USA
Rough cast. That buildup isn't doing anything to hurt your cross-sectional area but might be smoothing the surface out ever so slightly. If you want to do some cleanup to that intake that might actually do something look at port matching and/or polishing. That means taking off some metal and will be more work than is justified if you're only going to have it for a few months.
#3079457 - 07/29/13 01:03 AM Re: Cleaning my intake? [Re: Staleembrace]
Loc: Mississippi
Thanks for that tip. I know what port polishing is but I didn't know if this would cause any harm or not. See I'm a bong to dump this car and upgrade to something newer. I've had my eye on an 86 Monte Carlo as well however. I think it'd look great with a 468 dropped in haha! Anyways thanks for the help! Ill get her volte back up tomorrow afternoon and back running again. Much appreciated!
#3079462 - 07/29/13 01:27 AM Re: Cleaning my intake? [Re: Staleembrace]
wally6934 Offline
Loc: Wi
Good 2nd pic! I would not fool with it. That is nothing more than a oil streak. Cleaning it off will do nothing for you.
#3079555 - 07/29/13 07:28 AM Re: Cleaning my intake? [Re: Staleembrace]
dwcopple Offline
Loc: Michigan
2015 Chevrolet Silverado All-Star edition 4.3 Ecotec3 V6
2011 Chrysler 200 Limited 3.6L V6
#3079610 - 07/29/13 08:31 AM Re: Cleaning my intake? [Re: Staleembrace]
jfking106 Offline
Loc: GA
Simple Green is popular, and easily available at Walmart. I hear it will stain (darken) aluminum, though.
Page 1 of 2 1 2 >
