Originally Posted By: Rock_Hudstone
How do I tell which is damaged, the mandrel, deck or both?
Get the mower to a perfectly flat spot on concrete. Raise the deck to the highest setting, and with engine off and gloves on (to avoid the blade edges) turn the blades by hand. Place a measure under the blades tips and see if the tips pass around at the exact same height. If both blade tips are at a different heights as swing past the measured reference points, its your spindle shaft that is bent.
Now, while on the same flat concrete, run a measure around the perimeter of your deck, checking its height off the ground. If the measure shows an appreciable difference in different areas around the bottom lip of the deck, your deck is bent.
