I just finished applying this http://stingerelectronics.com/productDetails.aspx?ProductId=541&CategoryID=12 to the Accord. Really, it was purchased for the Miata, a tin can on wheels, to squeeze a bit more out of the modest stereo, and lessen nvh.
Application is easy but time consuming. Prep includes removing door trim, disconnecting electrical connectors, peeling off the moisture barrier, and cleaning the metal door panels. I used denatured alcohol.
Tools used: plastic trim tool, utility knife, rags for denatured alcohol, tennis ball, small roller, phillips screwdriver, small flathead screwdriver.
The product came as a nine pack, each piece 18"x32", but each of these folded into thirds. So effectively, 27 usable rectangles approx 6"x11". It is heavier than I thought it would be. The front is thick aluminum foil with a tar-like substance on the back, covered with "wax paper" that is peeled away before application. Cut the pieces from the "wax paper" side to avoid a gooey tar-like mess.
Taken this way I used 10 of the 27 pieces. 3 each for the front doors, 1.5 for each rear door, 1 for the trunk. I used much less than I thought I would.
Front door, naked. I did remove the speaker to apply product behind and to the hole:
Front door with Stinger:
Rear door with Stinger:
All in all it was an enjoyable, albeit time consuming, experience. I spent approximately 3 hrs today, start to finish, on the rear doors and trunk. Fuddy duddying around yesterday, making mistakes like putting the front door trim on without first remembering certain hardware had to go to the door itself, cost me time. In all probably around 4+ hours for the two front doors.
Again, easy, but time consuming. And not that expensive, $95 on Amazon for the nine- pack of which I used 3&1/3 pieces, or $35 worth for the doors and trunk.
Although I have not taken the car out for a drive I can say after listening to the factory stereo that this product, and I assume others like it, make a dramatic impact on the sound system performance. Music seems louder yet more finely detailed, which makes sense given the marketing claims of a reduction in vibration.
I'll update on road noise later. Oh, in case you were wondering, the tennis ball supplemented the roller and was for rounded areas.
