My sons 01 sc1 has a bad a/c clutch. It won't engage even with a can of r134 attached. With the ac switch on and the fan on full. i do measure 13 or so volts in the wire going to the clutch. The shops around me will only change the entire compressor to the tune of $800. No one nearby carries just the clutch. I can get a compressor from a u pull it yard for $50 bucks. I plan on removing the clutch from this compressor and installing it on the existing one. How hard and what tools do i need to remove and install the clutch?
Thanks
Thanks
