I have a 1995 Four Winns with a Volvo Penta SX Cobra outdrive (light gray colour) plate on side of outdrive says product number 3868156 type (left blank) gear ratio1.66 I believe it is a cone clutch.
I always used OMC Ultra HPF gearcase lube PN508318, yellow oil, but got discontinued. I now have been using Bombardier Evinrude/Johnson Ultra HPF gearcase lube PN 775601. But it seems this is not around now either, or I just have not found some. I was told Evinrude/Johnson Ultra HPF Pro is different?
Is Mobil 1 GL 5 standards, 75w90 okay for this drive? Supposedly, Mobil makes the Volvo Penta oil, but it is $20 +++ a litre.
I can't post a picture of the Bombardier oil for you.
Thanks
Ron3033
Thanks
Ron3033
