2013 Ford Focus ST, purchased November, 2013.
This is a daily driver with about 70:30 city:hwy with an occasional rush of turbo thrown in for good measure. Car had a Lucas UCL at 1/2 dose at every fill up. Also a K&N drop-in filter. Engine is a direct-injection variety.
For the 2.0 L Ecoboosts, I'm glad to see fuel dilution to be not an issue. Is this still an issue for Ford EcoBoosts?
I'd like to see the silicon numbers decline. Hard to say if it's from sealants or from the filter at this point. Is it common for newer engines to have higher silicon?
I went close to 12,000 km (7,500 miles) on this oil. My current (new oil) run is Pennzoil Ultra. Should I stick with 12,000 km or go for 14,000 km (8,750 miles)?
Other than that, the car has been an absolute joy and a thrill to drive!
Regards,
Andrew
Code:
Make/Model 2.0L GTDI EcoBoost I-4 engine
Fuel Type: Gasoline
Additional Info 2013 Ford Focus ST
Oil Type and Grade Pennzoil Platinum 5W-30
Oil Use Interval 11,753 km
MI/HR on Oil 11,753 km Unit/Location Universal
MI/HR on Unit 13,093 km Averages Averages
Sample Date 7/6/2013
Make Up Oil Added 0 qts
Aluminum 9 9 5
Chromium 1 1 0
Iron 22 22 13
Copper 65 65 4
Lead 3 3 0
Tin 2 2 1
Molybdenum 59 59 61
Nickel 1 1 0
Manganese 27 27 2
Silver 0 0 0
Titanium 0 0 2
Potassium 3 3 3
Boron 18 18 79
Silicon 34 34 18
Sodium 4 4 36
Calcium 2494 2494 2110
Magnesium 12 12 161
Phosphorus 725 725 737
Zinc 842 842 822
Barium 2 2 3
Values Should Be
SUS Viscosity @ 210F 58 55-63
cSt Viscosity @ 100C 9.65 8.8-11.3
Flashpoint in F 415 >365
Fuel %
Antifreeze % 0 0
Water % 0
Insolubles % 0.2
TBN 2.4 >1.0
"This first sample from your Ford Focus ST had more copper and silicon than universal averages, which show typical wear after about 10,500 km. This is one of the first few oil changes for this brand new engine, which is probably why those two elements read high. Copper is from brass/bronze parts and silicon is from harmless sealants used during engine assembly. Once wear-in material washes out, your engine should look like averages (if not better). The TBN was good at 2.4 since 1.0 or less is low for extended use. Try 14,000 km next and check back for progress."
Regards,
Andrew
Code:
Fuel Type: Gasoline
Aluminum 9 9 5
Chromium 1 1 0
Iron 22 22 13
Copper 65 65 4
Lead 3 3 0
Tin 2 2 1
Molybdenum 59 59 61
Nickel 1 1 0
Manganese 27 27 2
Silver 0 0 0
Titanium 0 0 2
Potassium 3 3 3
Boron 18 18 79
Silicon 34 34 18
Sodium 4 4 36
Magnesium 12 12 161
Zinc 842 842 822
Barium 2 2 3
Values Should Be
Fuel %
Antifreeze % 0 0
Water % 0
Insolubles % 0.2
TBN 2.4 >1.0
