I'm seeking recommendations for an oil to use in miniature timing motors which I rebuild. Up until now I've used M1 0W-20 and wonder if there's a more appropriate product. (ex: synthetic ATF??)
These motors turn at 3600 RPM and reduction gearing brings them down to slower speeds such as 1 RPM. They only contain about 1.5cc of oil and the bearings are lubricated by capillary action.
They run at about 100 degrees F. They run 24/7 and should last for many decades.
Proper viscosity should be approx. 35-45 cSt at 40 degrees C.
M1 0W-20 has worked just fine and is far superior to the original oil these motors were manufactured with but I'm always looking for improvement. Would ATF be better??
I'd like something I can purchase by the quart.
TIA
TIA
