I think that you may be referring to Auto-Rx, as it's a lanolin ester.quote:
Originally posted by moribundman:
I'm thinking, if it's not Made in Australia, it can't possibly be the best.
Any positives or negatives (besides the color) to report on this stuff?? Have you done a UOA on any oil which contained this additive?quote:
I am currently using CeraTec by LiquiMoly in my oil. It is a micro-ceramic additive -- looks like pale raspberry yogurt.
CeraTec (second from bottom)quote:
CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil.
Operational area: CERA TEC is added to motor oil and is self-mixing. CERA TEC provides extreme wear protection for all moving parts and friction surfaces in the engine.
How did you measure the before and after reults? I am thinking of using it in my Honda and performing compression, oil pressure, idle mileage, and emmission tests.quote:
Originally posted by raynorway:
Just finished treatment with Xado in my '94 Ford 7.3 IDI, no effects on power, mileage, engine noise or oil pressure. No UOA so far, but I'm really tempted to do one. (Posting back with results if so.) Expensive stuff, will not use it again.
Sounds a lot like the Ceramlub I just used on my brakes. Supposed to be a %30 solid content and probably similar technology to Ceratec. I like solid lubes just fine for slow movement/high heat type uses, but I'm not convinced about their uses in high speed applications.quote:
That's just not going to happen. And for their Repairing grease:quote:
a 10 fold increase in wear resistance and barrel life; an increase in firing flatness, but the key factor is an increase in firing accuracy by 2 to 3 fold!
What does that mean?? %80 of the part can be gone and this stuff will fix it??quote:
Compensates wear up to 80%
