I have a 02 Galant that i want to do a coolant flush to. I know it uses the conventional green colored Antifreeze/coolant. Correct me if im wrong on how to do a coolant flush.
1. Drain old coolant.
2. Add coolant flush cleaner (prestone)
3. Add distilled water u til full.
3. Run car for about 10-15 min
4. Turn heater to hot and air blow to fast
5. Let it cool for 10-15 min
6. Drain whats inside the cooling system
7. If kt looks still a bit dirty add more distilled watter and run once again same process as 3
8. Drain again.
9. If clean, fill with new green coolant(Supertech, Prestone, Peak, Advance Auto Parts Brand.
10. Run car to make sure all air gets out.
11. Fill tank where its suppose to.
My real conxern is how much coolant to add, because there will still be some distilled water on the block. Since tbis is a 4 cylinder should i just use the whole gallon of coolant. (I wont use 50/50) or can i? But wouldnt it be more water than coolant? Im sorta confused when it comes how much yo add afyer the flush. Tbis would be my first time doing aflush by the way!
8. Drain again.
