Engine Guard II filter + Restore & LM MoS2
Indiana
Today Clevy said an oil filter would be plugged with the oil additive Restore on board.
This oil filter was run for 5k miles with Napa All Fleet conventional 15w40 in my 1990 Chevy K1500.
There was TWO 6-cylinder sized cans of Restore added at beginning of the OCI. In the middle of the OCI, I added a can of Lubro Moly MoS2. This is a LARGE dose of Restore!!! And it was spiked with granular moly.
I see no problems here. Filter looked great. No collapsed media, all pleats were evenly spaced.
I see no oil filter clogging problem here.....do you?
Yep. That slime is blocking the oil passages. Mos2 doesn't plug them. Restore does. I found out the hard way on a 305. Fortunately I had a 350 to install.
That slime on the outer plates doesn't look like oil to me nor do I believe oil is getting through that slime.
Believe what you want.
Restore by its own admission claims to contain soft metals. Now unless those metals are nano sized do you really believe the filter isn't catching them.
That filter looks like it did all it could. I do not understand this fascination with adding additives to motor oils just to add them.
+1. More is not always better.
That media doesn't look very healthy to me either. Pull up a bunch of cut open filter pics, unless there is heavy engine sludge the media does not usually look "coated" like that. I will speculate that filter was spending a good amount of time in bypass before you replaced it.
I don't know enough about Restore or your engine to blame the Restore, but I have cut open multiple filters that had full doses of MoS2 in the oil and they looked perfectly normal.
Oh my....all three of you showed up at once. LOL!!! Nice. You can't resist, can you? It's like me and ice cream...I can't help myself.
In all fairness Clevy, when you rub the pleats with your finger, the residue is "greasy". I felt no abrasiveness to it at all, but it was "greasy", not "oily". So, obviously, the filter was catching some of the particulate matter found in Restore and possibly LM MoS2.
The question is, is the filter really plugged? Wouldn't a plugged filter begin to collapse or have pleat seperation if it was plugged for 5000 miles?
There is no way to prove this, but maybe this "greasy" material on the pleats, help improve the filter. Everyone knows a dirty filter does a better job than a clean one.
So, how do yo test to see if this filter is clogged? How do you test this? Can someone on this board "bench-flow" a filter on an apparatus? If so, let me run the Purolator classic I just installed for another 5k miles, and send this filter off to be tested for flow/filtration. I'd be willing to do that.
For what it's worth....the company that makes Restore told me before I added it to my oil that the copper, silver, and lead in their product is smaller than 10 microns and would pass through an oil filter. LM MoS2 claims the same thing. But ARCO claimed his filter was plugged immediately in his Honda Fit after adding a can of LM MoS2. Yet, he's the only one that has ever claimed that on here.
Hmmmm......
That's the restore being filtered out.
I'm a big fan of mos2 and I cut open all my oil filters since joining this site. Never have I had a filter look like that when using mos2 but I have seen them look like that using restore.
Its like a slimy sludge type gunk. Last year my younger brother used restore in his dodge with a 5.9. It did lessen the smoke coming from the tail pipe but he mentioned his oil pressure was all over the place. I switched his filter with a new one which fixed the fluttering gauge and cut open the filter with a sawzall and the media was similar to the pics above but thicker. I was confident the filter was in bypass. Restore is very bad stuff. Just read the contents and think about it. Soft metals. Sure they fill in any defects however unless those metals are dissolved completely in the carrier oil that has to mean there are particle sizes.
Do a used oil analysis and get a particle count on the insols. Lead and copper will be off the scale and in particle sizes that do more harm than good over the long term.
However Phishin you do whatever you like. Posting that filter pretty much proves my comment correct. That slime is what I was talking about,and your pics prove to me beyond any doubt.
Unless your engine is filled with sludge,which restore is certainly contributing to.
Better order some kreen.
And to be totally fair to my engine....it was filthy inside when I bought it 20k miles ago. I mean filthy. I scrapped sludge out of the valve train with screw drivers....that kind of dirty.
The truck also burns a HUGE amount of oil. Like a quart every 400-500 miles.
The oil is sooooo black after 1000 miles, it looks like tar. No matter what oil or filter I use.
After purchasing the truck, I ran 4 OCI's around 500 miles and manually cleaned under the valve covers. I've run 3 quarts of Kreen through it. I've also ran over 2 gallons of MMO through it. I've done about all I can to help remove as much internal crud as I can. I think this "greasy" stuff I'm seeing on the filter is mostly just sludge.
However, the truck runs sooooo smoth with Restore on board. It evened out my compression, like it said it would. My idle is super smooth now. Truck also burns less oil....down to a quart every 1200 miles or so.
Phishin, since you are asking for opinions I will offer mine (totally unbiased, never interacted with you before)
That filter looks completely clogged with a combination of oil and another substance
Fair enough. However that doesn't mean anything I said wasn't true. You posted this to discredit my comments on restore however basically you proved my point.
If you need restore to keep your engine alive I promise its short lived and you should be shopping for another engine ASAP.
Mos2 would have likely achieved the same result but it would have taken a bit longer.
For example I have a 5.0 that smoked on start up and had 150 in 3 cylinders and 155 in the other 5. Mos2 stopped the oil puff at start up and all cylinders are 175 or more. It took 1500kms before it completely stopped smoking but that 5.0 now consumes no oil whatsoever and I'm running 5w-20 in it just as a test.
Restore plugs filters,period. What is in that filter is sludge and restore. I've seen it more than once,when restore was the only additive involved.
Restore is like Lucas. Use it in an engine that you know is dying,and you aren't going to fix.
How can we prove the filter is plugged or not? How can we know if this filter is stuck in by-pass because there is no flow?
You would have had to test it before cutting it open.
Regardless based on what is visible if it wasn't in absolute by-pass flow was certainly constricted.
Anyways I do thank you for calling me out and posting pics. You've proved my point based on the pics provided. And restore hangs around for awhile. You'll be getting mud like that as the soft metal wears off the worn spots.
I've got to wonder why you would add both additives. Moly plates metal. Adding restore will either force the moly to plate the restore and come off with it as it wears off,or the moly will plate the metal then the restore can't adhere,so in effect they are working to achieve the same goal but doing it with different elements and in effect compromising each others layer.
Anyways thanks for the pics.
Unless you ran that oil for more than 5k there shouldnt be this much gooe-ness in there.
The restore defenetly did a job on this filter.
Out of curiosity why so much additive? MoS is not cheap migh as well go to walmart buy 5qt jug and call it a day.
The filter doesn't look that good-but, remember, his engine is already pretty much toast anyway, so as long as it doesn't spin a bearing I wouldn't worry too much about it!
First off, I didn't prove anything. We don't know if the "greasy" stuff on the filter is Restore or crud from my engine. But I'm glad that these cell phone pics are so conclusive to you.
Both additives because they do different things. The Restore "plates" out in scratches and voids with mechanical forces. It's not different than smearing bondo into a scratch with your finger. That's how Restore works...and that's how it straightens up the scratches in the cylinder walls.
MoS2 makes an ionic bond with metal and itself to form a matrix/crystal on the surface of metal-to-metal contact points where extreme pressure and heat can be found. Would Moly "plate out" on the same areas that Restore might be working....it's possible. Are they "competing" against eachother? No. Restore can be smeared over Moly and Moly can bond over Restore. These are NOT chemical reactions with limiting reagents.
Well, I put on a Purolator Classic last night and Restore is still on board. Is there anyone on here that can bench flow this filter for me after I've run it for 5k miles? I'd like a brand new filter tested as well for comparison.
Lastly.....Why is there no spring in this filter? What is keeping it ADBV shut?
Does this 'dimple' found under the topside of the can actually function as a spring to keep the adbv closed?
I was in a hurry last night....I think I understand it better now....
There is another ADBV valve at the top of the can, and there is a "leaf" spring under the rubber valve, right?
I'm no fan of 99% of miracle-in-a-can additives, but I have no direct experience with Restore or MoS2.
Having said that, that filter is clogged. I don't know whether by the Restore or by sludge, but it's definitely toast.
Slightly off-topic: are LubroMoly and LiquiMoly the same company?
I'm more interested in the Mighty Filter manufacturer, than the additives used. It looks to me to be a Purolator made filter now. Confirms another poster's dissection some time back. In the past they had been made by Champ.
I'd like to see the other side of the tapping plate and the dome end endcap to look at the bypass (if it has one, GM?), but still fairly certain it's a Puro made filter, similar to a Classic.
Yeah the media looks saturated and gucked up, but considering everything it looks as though the filter itself held up.
Thanks for the pics.
