Is Supercool Super Premium Ester oil safe for engine oil use?
http://www.supercool.ac/products/automotive-products/polyol-ester-oil-8-oz/
I own a 2005 Infiniti G35 with the noisy VQ35DE engine, which Nissan and Infiniti recommend only using Ester oil in to quiet down the loud ticking and knocking noises...my question - Is this Ester oil safe to use in it? (Even though it's recommended for A/C compressors and clearly reads compatible with R134 & R12 Refrigerants on the bottle and product description & is made for only this use.) I've read that Ester is an additive to conventional motor oil and that's what most companies actually do to make their ester blends, ester is ester aside from the different compounds used to make specialized esters...so instead of paying $12 per quart of Nissan's 'special' ester oil can I use this much cheaper alternative and just add it in myself?
Thanks for your input and help in advance.
