MolaKule
Staff member
Quote:
What do the additive packages look like? Do they use the same type of base oils?
Okay, assuming you are asking about recip (piston engine oils), the base oils are mostly GroupII base oils with very small amounts of other groups to enhance performance.
The viscosity or viscosity spread is determined primarily by a mix of selected base oil viscosities.
Th anti-wear agent is mainly a no-ash phosphorus component.
The dispersant is a no ash succinimmide agent.
