Quote:
Quote:
While it wouldn't be my first choice based on cost for construction and efficiency, sure it will work fine.
Sure does work fine. There's zero wrong with the A02 except for prejudice from certain sectors of the public.
Again: absolute particulate filtration is a meaningless concept except for marketing purposes. There are more important things for engine longevity than capturing every last particle, no matter how small; A01 and A02 capture the important ones, ignoring the unimportant ones in favor of much-more-important flow and pressure.
Strokes for folks and the A-02 still wouldn't be and isn't my first choice. And while improved efficiency may be meaningless to you, there's zero downside to using a more efficient filter than the Honda OEM rock catchers especially using everyday dealer price as comparison.
And once again, there's no science to back the false assertion that oil filter flow is a significant factor in pc use. Engines themselves are typically 15x more restrictive than any filter, thus oil filter flow is an insignificant consideration. But, that's a discussion for the oil filter board.
That said, there's some folks just have a bias for oem labeled products whatever they may be. If ~65%@20um efficiency is what one seeks, the A-02 fills the bill.
