ATP turbo store has injectors for Abarth/500T(error) for under $400. They claim that it is 100% drop in without any changing to ECU.
We all know e85 benefits turbo.
I'm thinking about those, have couple gas stations that sell e85 near me for about $1 per gallon lower than 93,but price is not the reason.
I were wondering is it ok to run car on gas, if e85 is unavailable? Will ECU react and spray less? Will fuel get fully burned with 30% more spray injectors, if you have MM piggy back on race mode and sport mode on(it completely transforms car behavior, and obviously burns more fuel and changes timing)
if it won't, you will dilute your oil pretty bad, right?
So my main question is, do I risk anything if I happen to be in the middle of nowhere and there is no e85 to fill up? And oil will need to be changed more often if I happen to run e-85?
